Bad Vibration. Please Help? - JeepForum.com
post #1 of 9 Old 01-30-2008, 08:48 AM Thread Starter
metal_kid17
So I put in my SYE and CV driveshaft and everything was nice. It all went back together nicely and what not. I figured while I had it all out I would go ahead and change all the U-Joints and everything as well. Well, when I finally got it all back together I took it for a drive. No more vibration taking off but in high 2nd gear to 4th gear I have a bad vibration and I'm completely puzzled. Really the only thing that I could think of is that the driveshaft isn't balanced right but I don't know. If anyone has any suggestions I would be willing to try anything! THANK YOU!!!
91 YJ, 2.5L, 4'' RE Lift, SYE and CV driveshaft, 33x12.50 Super Swamper TSL Radials
metal_kid17 is offline
post #2 of 9 Old 01-30-2008, 12:06 PM
Brown Dog
Vendor
Brown Dog's Avatar
Was this a new CV driveshaft? If so, it is probably not out of balance.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #3 of 9 Old 01-31-2008, 05:09 AM
dankeenan
Did you shim the axle to re-align for the SYE?
dankeenan is offline
post #4 of 9 Old 01-31-2008, 06:36 AM
bamato
bamato's Avatar
Shims are usually required. I had to use 8* shims in my axle to rotate the pinion up to point it at the yoke of the t-case.
/l , [____],
l---L--?lllllll?-
()_) ()_)----)_)
Mud is your Friend :)
Tread Lightly
Please help keep our trails clean for future generations to enjoy outdoor recreation as well!
bamato is offline
post #5 of 9 Old 01-31-2008, 07:37 AM
crb577
you most likely need to shim the pinion up towards the SYE I had the same thing but i cut and rewelded perches for my 8.8 anyway
1993 Jeep Wrangler
4.0L Tom Woods rear HD shaft
D30 w/yukon alloys, lock right, jb4x4 bracket, Rusty's HD tie rod 8.8w/ LSD,SOA xj rear 100" wheelbase, homemade greasable boomerang shackles, SS braided lines, 1" prothane body lift, 35" TrXus M/T, smitty built XRC.
lots of gen right armor and rear stinger.
crb577 is offline
post #6 of 9 Old 01-31-2008, 09:50 PM Thread Starter
metal_kid17
its got 4* shims in it from when i installed the lift... im guessing thats not enough then? where can I get the shims?
post #7 of 9 Old 10-26-2009, 01:32 PM
lonepunker
/l,[___],
l---L--?llll?-
(_) (_)----)_)
thats freakin awesome
E CLAMPUS VITUS
Billy Holcomb chapter 1069
lonepunker is offline
post #8 of 9 Old 10-26-2009, 01:59 PM
flame0086
This great picture is from rusty when I had vibration questions.
100 mpg!! Western Washington Univeristy X-Prize Team
Support Search and Rescue
Get Lost
flame0086 is offline
post #9 of 9 Old 10-26-2009, 02:52 PM
lonepunker
mine is already set p that way, and it still vibrates in 2wd.
however, when i shift into 4wd high it greatly reduces the vibration.
it starts in 3rd gear at around 1500rpm and it mellows out(but not comletley) around 2000rpm. does the same all the way thru 5th gear.
any thoughts?
E CLAMPUS VITUS
Bad Vibration. Manard TJ Wrangler Technical Forum 3 02-25-2008 05:26 PM
Odd vibration JeepPirate TJ Wrangler Technical Forum 4 01-14-2008 12:03 PM
vibration igolf JK Wrangler Technical Forum 20 12-17-2007 07:26 AM
Vibration henri TJ Wrangler Technical Forum 13 04-13-2005 07:25 AM
big vibration when I hit 70 mph drunkinjacket TJ Wrangler Technical Forum 1 02-03-2005 08:52 PM
