Bad Slave Cylinder? - JeepForum.com
post #1 of 8 Old 11-15-2006, 04:40 PM Thread Starter
ssfitz
Bad Slave Cylinder?
My clutch pedal is squeaking and grinding like a mofo. I grabbed a can of WD40 and a flash light thinking it was just a sticky joint or something but it is coming from the black cylinder on the drivers side of the trans. Is this "fixable" or is it something that needs to be replaced? And if it needs to be replaced, does the trans have to come down with it?
The trans shifts fine but it is just the clutch pedal.
Thanks.
ΜΟΛΩΝ ΛΑΒΕ
94 YJ 4.0 HO. 3.5" Black Diamond suspension lift with 2" shackles on 33x12.50 MTR (new design) tires with 15x8 Mickey Thompson Classic II's. SYE with CV Driveshaft. Very Rare Teal Green paint. Herculined tub.
ssfitz is offline
post #2 of 8 Old 11-15-2006, 06:32 PM
bharris68
I was grinding a hair last week and my pedal was engaging way, way down on the floor. Turns out that I'd not checked the actual clutch Fluid level in FOREVER!
After removing the support that runs directly OVER the reservoir cap, I added fluid to the proper level and hooray! It's all better!
Havea peek there first.
bharris68 is offline
post #3 of 8 Old 11-15-2006, 08:10 PM
jimaug87
check the fluid first.
have you noticed the clutch engaging at a lower point at all? is it tough to get the transmission into gear from neutral?
usually its tough to shift if your slave/master is going. if the master connected to the pedal correctly?
does anyoneknow if the 94 has the internal or external slave?
if its internal the tranny has to come down, if its external it does not.
jimaug87 is offline
post #4 of 8 Old 11-16-2006, 03:40 AM
Broken
AX15 is external AX 5 is internal
Broken is offline
post #5 of 8 Old 11-16-2006, 05:24 AM Thread Starter
ssfitz
Trans shifts fine. No grinding and no trouble getting into any gear. I can feel some tension in the clutch pedal and it squeaks at the slave cylinder.
ΜΟΛΩΝ ΛΑΒΕ
ssfitz is offline
post #6 of 8 Old 08-24-2007, 04:33 PM
berman95
Did you ever find out the problem?
I have the same thing happening. Clutch pedal squeaks going in or out but no tranny problems. When my dog is sitting next to it in the driveway his ears perk up cause he thinks its a squeaky toy.
berman95 is offline
post #7 of 8 Old 08-13-2011, 04:21 PM
Red91xj26
my ax15 is internal
91 Jeep Cherokee Laredo (Ruby) My Build Thread
00 Jeep Cherokee Sport (UnNamed) Build thread soon.
Red91xj26 is offline
post #8 of 8 Old 08-13-2011, 04:27 PM
Xpress
Holy thread bump Batman!!
All about that unibody life.
Xpress is offline
slave cylinder? DanyJeep YJ Wrangler Technical Forum 15 08-21-2011 04:36 PM
How do you know whitch one is bad, Master Cylinder or Slave Cylinder? Morgan_TJ TJ Wrangler Technical Forum 19 08-06-2008 10:00 AM
how to tell if ur slave cylinder is bad? Spigger73 YJ Wrangler Technical Forum 9 01-27-2008 07:14 PM
Slave Cylinder Toyandgadgetguy YJ Wrangler Technical Forum 8 09-14-2005 10:43 PM
Clutch, Master Cylinder, and Slave Cylinder replaced and problem not solved.... loudog3114 TJ Wrangler Technical Forum 7 08-31-2005 09:37 AM
