Bad NV3550 - JeepForum.com
post #1 of 4 Old 04-13-2010, 01:55 PM Thread Starter
Mickey-D
Bad NV3550
I just recently installed a new NV3550 from HighImpact.com on my 93 2.5L YJ and all is not well. It "clunks" when I let of the clutch, grinds when shifting into third, and rattles in 4th and 5th. HighImpact does not think it's the transmission. Do any other of the proud NV3550 owners have any experience with this issue? Any suggestions of something else causing these symptoms?
Mickey-D is offline
post #2 of 4 Old 04-13-2010, 02:00 PM
SaxManClay
I know for a fact that those transmissions are louder than most. 1st to 2nd gear is always a work-out, but I've never grinded when going into 3rd though. And there is a noticeable volume difference when when I'm stepping on the clutch or not, but no slamming. I would have a shop check it out to see if it's bad, then call highimpact again.
My Jeeps name is TUG!
What I'm all about.
SaxManClay is offline
post #3 of 4 Old 04-13-2010, 02:19 PM Thread Starter
Mickey-D
I took it to a shop, he drove it for 20 minutes, and said something is not right. He said it sounds like a bad bearing.
Mickey-D is offline
post #4 of 4 Old 04-13-2010, 03:27 PM
vector6
sounds like a normal NV3550 to me..
mine makes noise, is rough 1st to 2nd.. but fine 3 > 4 > 5...
shift this tranny slow... its not a sportscar.... also i use Synchromesh Manual Transmission Fluid (32 oz.) by Pennzoil - Part 3501 - Advance Auto Parts
oil in mine works alot better i feel with this oil
vector6 is offline
New NV3550 at 50K? Really? AUWillys TJ Wrangler Technical Forum 8 05-18-2009 09:22 PM
Ax-15/nv3550??? KenJ95 YJ Wrangler Technical Forum 4 03-07-2009 01:04 AM
Do I have a AX5 or NV3550? cjyjnowtj TJ Wrangler Technical Forum 9 07-24-2008 08:02 PM
Nv3550 Rigged TJ Wrangler Technical Forum 0 04-23-2007 05:30 PM
NV3550 Oil BeachJeepin' TJ Wrangler Technical Forum 9 02-11-2006 10:08 PM
