Bad Ignition Coil ?? - JeepForum.com
post #1 of 7 Old 05-25-2013, 10:06 PM Thread Starter
gogators
Question on my 4.2.
What will cause the ignition coil to have a orange spark? Shouldnt the sparsomething else or white? I pulled a couple of plug wires and they have a orange spark also. Could something else cause the weak spark?? The Jeep will run for a second and die.
Any help would be greatly appreciated..
gogators is offline
post #2 of 7 Old 05-26-2013, 08:17 AM
Louie4
Get the battery and coil checked. Autozone can check both (as long as they have an ohm meter on hand). Might as well get the alternator checked too I suppose.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 7 Old 05-26-2013, 09:28 AM
Old4X
1990 CJ7
Are you using a spark checker? If not you are risking burning up your coil, cap, rotor,ignition wires, or ICM by just pulling the high voltage wires.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #4 of 7 Old 05-26-2013, 12:29 PM Thread Starter
gogators
The battery is good. Tested the coil and it read 9.1 with the multimeter set on 20k
gogators is offline
post #5 of 7 Old 05-26-2013, 12:55 PM
Old4X
1990 CJ7
What were you looking for in your test?
Old4X is offline
post #6 of 7 Old 05-26-2013, 01:49 PM
Louie4
Per the Haynes Manual for the 1987-1990 carbureted models the primary resistance should be from 1.13-1.23 ohms. Secondary resistance should be 77-93 kilo-ohms.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #7 of 7 Old 05-27-2013, 07:40 AM Thread Starter
gogators
The primary tested within range, the secondary was at 91 k ohms ..there was just a small amount of oil inside the plug wire goes if that matters.. thanks
gogators is offline
