Bad ignition - JeepForum.com
post #1 of 3 Old 02-23-2014, 10:27 AM Thread Starter
BrandonYJReed
Bad ignition
So my ignition is going bad/is bad. When I got to turn it off you have to go past the 'lock' portion for it to maybe shut off, and you can wiggle the whole ignition. So my question is, A. Should I replace the ignition(and turn signal cancel while
I'm there), or B. Just swap the whole Column out for another Gm column from the junkyard and gain a tilt wheel out of the deal. I may be able to get a column from a late 80's s10 blazer for free also. Opinions?
-1990 YJ, 2.5L, AX-15, lifted, locked, on 35's.
-1999 XJ, 4.0, AW4, lifted 4.5", JK Rubi take offs.
BrandonYJReed is offline
post #2 of 3 Old 02-23-2014, 01:21 PM
rubisean
adjust the ignition switch first, not the lock cylinder but the actual ignition switch on the base of the column.
rubisean is offline
post #3 of 3 Old 02-23-2014, 04:06 PM Thread Starter
BrandonYJReed
Do you have a picture of this? I have no clue what ya mean
