bad idle boggy acceleration - JeepForum.com
post #1 of 15 Old 09-03-2011, 02:29 AM Thread Starter
acoustal
1987 YJ Wrangler
hi im new to the jeep forum. this is my first post so here it goes... hope im putting this in the right section.
So this week say 4 days ago i started to notice my 87 yj 2.5 5 speed manual was taking longer than usual to start. the engine would have a long crank then finally start up. If I stopped to run in the store and start it up again it was crank then die. Then start right up the second time I tired. So i went down to the parts store and they said my battery was almost dead. Replaced the battery. Started the same as before but now the engine idles really rough and when i accelerate it feels like it may be running out of gas. speeds up slows down. when i get to the desired speed it runs more smooth. could this be a bad fuel pump or ignition coil
fuel filter is good
new plugs and cap 4 mo. ago
new wires, cap, rotor maybe a year ago
ignition coil 2 years ago.
new exhaust manifold 2 months ago (didnt change the O2 sensor)
any help is appreciated
oh and if i posted this incorrectly pls give pointers
acoustal is offline
post #2 of 15 Old 09-03-2011, 02:34 AM
Boodyrider
Fuel pump pressure. Check it at idle and under load.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #3 of 15 Old 09-03-2011, 02:38 AM Thread Starter
acoustal
1987 YJ Wrangler
yea thats where i was thinking to start. i was going to try to get a gauge from my brother in law (if he has one that is) to test pressure this weekend. just wanted to know the best place to start.
acoustal is offline
post #4 of 15 Old 09-03-2011, 07:15 AM
alex101
1987 YJ Wrangler
hey acoustal i noticed i have been have that same problem just recently with the slow down speed up. let me know how your fix goes so i can go about with mine
alex101 is offline
post #5 of 15 Old 09-03-2011, 08:40 AM
pasinbuy
Also look at your fuel plunger. Look down your carb with motor off. Move accelerator and see how much gas is injected into your carb. Easy fix. Also look at your choke for start up problems.
While you have this problem you are going to have battery problems. Throw the charger on the battery over the weekend.
pasinbuy is offline
post #6 of 15 Old 09-03-2011, 08:50 AM Thread Starter
acoustal
1987 YJ Wrangler
will do alex.
pasinbuy, my jeep is throttle boddy. i did take the housing off the throttle body to see if it was hanging up at all but it seemed to be in working order. last time i had acceleration issues it was the ignition coil that was the culprit but that time i had random miss fires in the intake. this time it seems more like insufficient gas. ive never ran out of gas in a vehicle but i imagine this it what it would be like?
are there any fuses or sensors i should check? cause this was a gradual thing. i kind of could feel a little hesitation before it decided to go down hill after changing the battery
acoustal is offline
post #7 of 15 Old 09-03-2011, 09:15 AM Thread Starter
acoustal
1987 YJ Wrangler
oh this could play factor to the problem not sure tho. when we did the exhaust change my bro in law pulled all the sensors and wires apart before i got a chance to label them. so we had to do some guess work to put them back together. maybe got one wrong? but if so it wouldnt run fine for 2 months would it? first few connections ran bad but then finally got it what i assumed was right because it ran normal.
acoustal is offline
post #8 of 15 Old 09-03-2011, 10:05 AM
pasinbuy
Originally Posted by acoustal View Post
will do alex.
My mistake, I thought the 87 was carbed.
pasinbuy is offline
post #9 of 15 Old 09-04-2011, 11:27 PM Thread Starter
acoustal
1987 YJ Wrangler
anyone else have any areas to look into before i either get into replacing a bunch of parts or if the az weather is too hot i might save my self the trouble and take it to a shop
check out my yj build in progress
http://www.jeepforum.com/forum/f22/acoustals-build-thread-1261122/
acoustal is offline
post #10 of 15 Old 09-05-2011, 08:21 AM
cstone94
Are the cats still on your exhaust?
95' YJ - Warn Bumpers/Tire Carrier/Winch - 2.5L - 6" Skyjacker Suspension Lift - 4.10's - Locrite Locker - Dana 35/30 - 35" BFGoodrich KM2's
11' F250 - DD
1982 Toyota Pick-Up - Spray-On Yellow Rhino Lined - Chevrolet 305 H.O. - SM465 - NP208C - All-Pro Off Road 5" Springs - 35x15.50x15 Super Swampers
cstone94 is offline
post #11 of 15 Old 09-05-2011, 01:11 PM Thread Starter
acoustal
1987 YJ Wrangler
I am thinking so cause ive never messed with them and it was pretty stock when I got the jeep. And I think you have to have them in az to pass emissions. Ill have to crawl under there and find out for sure
acoustal is offline
post #12 of 15 Old 09-05-2011, 02:35 PM
cstone94
If they are, I'd run it by a shop and get them to rub a backpressure test.
cstone94 is offline
post #13 of 15 Old 09-07-2011, 04:38 PM Thread Starter
acoustal
1987 YJ Wrangler
had the fuel pump swapped out by a local mechanic for 340. its 106 and i didnt feel like spending all day doin that. they said that pump and components were complete shot and were surprised it still pumped at all. runs normal now. so now time for upgraded front suspension. got a weird clunk coming from passenger side front tire
acoustal is offline
post #14 of 15 Old 09-07-2011, 08:00 PM
cstone94
Good to hear you got it fixed! And what kind of clunk?
cstone94 is offline
post #15 of 15 Old 09-07-2011, 08:42 PM Thread Starter
acoustal
1987 YJ Wrangler
not exactly sure since i dont know the correct names of all the pieces but i think i need a few new bushing and ball joints. im thinkin they are all original so they need to be swapped out
acoustal is offline
Acceleration Hesitation - NOT IDLE muttytruckster JK Wrangler Technical Forum 12 01-13-2015 01:03 PM
Rough Idle and Acceleration...Sometimes a1lane TJ Wrangler Technical Forum 2 08-19-2010 01:41 AM
2.5l ac blows only at idle/low acceleration born2trod TJ Wrangler Technical Forum 4 06-02-2009 02:06 AM
Boggy Start WillysGSR TJ Wrangler Technical Forum 15 05-25-2009 07:52 PM
Idle/Acceleration problems jeepcostarica YJ Wrangler Technical Forum 9 01-09-2005 09:26 PM
