Bad Idle After Team Rush - JeepForum.com
post #1 of 16 Old 08-23-2009, 09:53 PM Thread Starter
CajunHiker
So I finally finish my TR upgrade today. Fired up pretty easily, choke engaged idle at around 1400rpm. Sounded nice & smooth. I let it warm up and tapped the gas to disengage the choke. Idled around 700rpm, again no problem. But then after idling for 5 minutes or so, it died. It was almost like it ran out of gas, in fact I did add some gas to the tank and even a capful into to the carb. It took a couple of tries adding capfuls of gas to get it running again, but now, it won't hold an idle. I've just done a carb rebuild and the engine was running okay prior to the TR with the exception of an occasional miss at idle.
Anyone had this happen after a TR upgrade?
CajunHiker is offline
post #2 of 16 Old 08-24-2009, 11:41 AM Thread Starter
CajunHiker
Forgot to mention, it's Nuttered and has the Carter carb. Is a carb adjust usually required after doing the TR?
Anyone?
post #3 of 16 Old 08-24-2009, 11:42 AM
antec
Anyone?
what do you have the timeing set at. after my team rush the timeing was off about 5 deg
antec is offline
post #4 of 16 Old 08-24-2009, 11:48 AM Thread Starter
CajunHiker
I didn't recheck my timing. I believe it's around 6d btdc. I'll have look at it again. Like I said, it was running fine for 5 minutes or so.
post #5 of 16 Old 08-24-2009, 11:52 AM
antec
what coil are you runing??
antec is offline
post #6 of 16 Old 08-24-2009, 11:56 AM Thread Starter
CajunHiker
Stock coil, didn't change it.
post #7 of 16 Old 08-24-2009, 12:00 PM
antec
you might not have the voltage to run that cap then i would try to get TFI coil or a better stock style coil li9ke from MSD.
antec is offline
post #8 of 16 Old 08-24-2009, 01:02 PM Thread Starter
CajunHiker
You're gonna have to explain that one to me.
post #9 of 16 Old 08-24-2009, 01:13 PM
Fernando
Fernando's Avatar
1987 YJ Wrangler
Make sure you did not plug some vacuum hose by mistake while doing the upgrade, if you have fuel and spark but does not hold an idle, it sounds sensor related to me, you still have the stock carb, which makes me think you may have the spaguetti of hoses there too... make sure you did not unplug something by mistake.
The coil does not have to do with it, you can run the rotor and cap with a stock coil, however you must not gap the plugs with the stock coil because your spark will get weak current wise. If you have the stock coil and gapped the plugs, I recommend you go back to original plug setting.
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #10 of 16 Old 08-24-2009, 01:18 PM Thread Starter
CajunHiker
As stated previously, used existing stock coil. New cap, rotor, wires & plugs.
post #11 of 16 Old 08-24-2009, 01:32 PM
Fernando
Fernando's Avatar
1987 YJ Wrangler
I edited my post, please take a look
Fernando is offline
post #12 of 16 Old 08-24-2009, 01:42 PM Thread Starter
CajunHiker
Same plugs as I was using before, Champion RFN14LY w/ 0.035" gap. It's been nuttered with most of the emissions related vacuum lines gone.
post #13 of 16 Old 08-24-2009, 02:41 PM
Fernando
Fernando's Avatar
1987 YJ Wrangler
When you say it won't hold an idle, does it die as soon as you let go of the throttle? does it stall or something?
Fernando is offline
post #14 of 16 Old 08-26-2009, 07:15 PM Thread Starter
CajunHiker
Hats off to you antec, indeed my timing had drifted with the change of the dist cap. Thanks.
post #15 of 16 Old 08-26-2009, 10:17 PM
antec
it's b/c of the adapter and the cap. if you every have to change the adapter check the timeing it's something with the way thay make then no two are the same lol. i have worked with a lot of ford 300 lol
antec is offline
team rush vs HEI bigorangeyj YJ Wrangler Technical Forum 6 12-19-2009 01:00 PM
HEI or Team Rush?? bjbrowder YJ Wrangler Technical Forum 17 11-19-2009 10:39 AM
Team Rush frustration ScottsYJ YJ Wrangler Technical Forum 8 11-22-2008 06:17 PM
Hei or Team Rush ? Which is best ? mtidwell YJ Wrangler Technical Forum 11 10-17-2008 11:38 PM
team rush NJscott YJ Wrangler Technical Forum 2 06-10-2008 07:16 AM
