bad gas mileage - Page 2 - JeepForum.com
post #16 of 25 Old 02-02-2013, 09:04 PM
Que89YJ
Sorry. I am on my cell and can't post it. Search the forum for a thread "how to check fault codas" and if you you can't find it I will post it tomorrow.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is online now
post #17 of 25 Old 02-02-2013, 10:00 PM Thread Starter
smithj156
so i got a code 52 o2 sensor rich but the check engine light never came one but with the key trick it came on
smithj156 is offline
post #18 of 25 Old 02-02-2013, 10:08 PM
Que89YJ
Exactly like I said. Obd I will not always light the cel.
Fault codes:
No Start:
post #19 of 25 Old 02-02-2013, 10:14 PM Thread Starter
smithj156
thanks going to get a new one in the am that should help with mpg big time
post #20 of 25 Old 02-03-2013, 09:05 AM
Que89YJ
Rich is not a bad 02 sensor. It is usually high fuel pressure or a temp sensor issue.
Fault codes:
No Start:
post #21 of 25 Old 02-03-2013, 09:59 AM
kenh
Not to thread jack, but I filled up yesterday and got 8 mpg, ugh. Time to check my codes also I guess.
kenh is offline
post #22 of 25 Old 02-03-2013, 02:08 PM Thread Starter
smithj156
well 2 wires were broke off
post #23 of 25 Old 02-03-2013, 03:00 PM
Que89YJ
Broke off! Well it makes it easy to diagnose. Pull the battery after you put the new one in to reset the ecu.
Fault codes:
No Start:
post #24 of 25 Old 02-03-2013, 03:21 PM Thread Starter
smithj156
ya it looked almost new too but with 2 broke wires lucky it didnt arch out and fry ecm
post #25 of 25 Old 02-03-2013, 03:45 PM
Que89YJ
The ecm its designed to take a direct short on any of its power supplies. The only thing power related to kill it is disconnecting and reconnecting battery power when you have it running and loaded with things turned on. That is the cause of most of the blown caps in the ecu that people experience.
Fault codes:
No Start:
