bad gas mileage - JeepForum.com
post #1 of 25 Old 01-30-2013, 03:07 PM Thread Starter
smithj156
bad gas mileage
i have a 93 jeep wrangler yj with over 200k on it was towed behind an rv. its got the dang 4cyl in it.. it gets maybe 10mpg is this normal its a 5 spd and i have 30in tires on it what could i do to help my mpg
smithj156 is offline
post #2 of 25 Old 01-30-2013, 03:26 PM
jokerchief462
Should be around 15mpg. Tune up maybe.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 25 Old 01-30-2013, 03:30 PM Thread Starter
smithj156
i know i have some exhaust problems and the axles are stock i want to go with 33s what should for 33 besides lift i got the jeep for a hell of a deal
post #4 of 25 Old 01-30-2013, 03:31 PM
andygio71
basic maintenance for starters (if you havent done it already), air and oil filters, oil change, plugs, wires, etc. read up on upgrades for your motor (i've got a 4.2 so i'm no expert).
and dont forget, bigger tires tend to hurt gas mileage. also, if your speedo hasnt been corrected for the tires, it will be messing with your mpg numbers
andygio71 is offline
post #5 of 25 Old 01-30-2013, 03:33 PM
ZeroGravity
33s aren't going to help your cause.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #6 of 25 Old 01-30-2013, 03:53 PM Thread Starter
smithj156
i know but if i put gears in it wont that help
post #7 of 25 Old 01-30-2013, 04:05 PM
Old4X
1990 CJ7
Not much. It will be worse, but not as bad as stock
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #8 of 25 Old 01-30-2013, 04:08 PM
flcracker
I have 31's and get over 15 and as high as 17 if I'm nice to it....
2.5, 5 speed
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is online now
post #9 of 25 Old 01-31-2013, 08:49 AM Thread Starter
smithj156
flcracker how many miles do you have any mods to engine
post #10 of 25 Old 01-31-2013, 09:19 AM
flcracker
Not sure what mods I do have, whatever it has, it came with most of them. I did go to an electric fan and I do see a spacer under the throttle body but I don't know if it has a 4.0 throttle body or upgraded injectors or what....
post #11 of 25 Old 01-31-2013, 09:23 AM
Que89YJ
Exhaust problems = leak in the exhaust manifold = O2 sensor think its running lean = dumping more gas = bad mileage
Fix your exhaust leak and replace your O2 sensor
Que89YJ is offline
post #12 of 25 Old 01-31-2013, 02:51 PM
pete1991YJ
X2 this. Do what Que says, along with a complete tune-up. Look for any and all possible vacuum leaks, replace hoses or use clamps. Re-torque and tighen down the intake and exhaust manifold bolts at the cylinder head - they have a known habit of working loose and killing the MPG's.The 4-bangers are very sensitive to these things. Clean out the TB, the IAC, etc. fresh plugs, cap rotor and wires, air and fuel filters, the whole 9 yards.
My 1991 is getting a solid 20 MPG's on 31" tires with stock gears and it goes on the NY thruway. If you want 33" tires then it would be a good idea to re-gear yours. But get it tuned up first.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #13 of 25 Old 01-31-2013, 07:36 PM Thread Starter
smithj156
i didnt see an 02 sensor when i looked the cat looks pretty bad so im going to cut it out and put a new muffler on there... no check engine lights on... the guy i got it from just did a tune up and replaced the fuel pump.. going to replace the fuel fillter again run some seafoam threw it but the spray kind.. also going to check all those bolds any one got the specs for that
post #14 of 25 Old 01-31-2013, 07:39 PM
Que89YJ
Did you check the codes the way the link I posted. I hate to keep asking but you should see some codes.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #15 of 25 Old 02-02-2013, 08:48 PM Thread Starter
smithj156
what link que89yj
