Bad Charcoal Canister? - JeepForum.com
post #1 of 7 Old 05-12-2012, 04:55 PM Thread Starter
lower7
The jeep starts fine and idles great. However, once it warms up something switches and it begins to idle erratically. However, if i pinch off the vac line between the CTO and charcoal canister(purge) it cleans up. If i remove one of my ported vac lines there is pretty good suction heading in the direction of the charcoal canister. I have the Howell kit and all my lines are connected as per their diagrams. It appears that the purge valve on my charcoal canister is stuck open. Maybe? I took apart the purge valve on the canister and it appears to be in working order. I cleaned it up a bit and put it back in and as soon as it warmed back up, it started it again. Could this be a bad CTO or is it the charcoal canister that is bad? Is there a source for new charcoal canisters?
Thanks,
John
lower7 is offline
post #2 of 7 Old 05-13-2012, 12:35 AM
timatoe
timatoe's Avatar
My understanding is that they (AMC then Chrysler) used the same basic canister for twenty some odd years and they are not available any longer new even from a dealership. I had to get a used one from J&W Jeeps in Antelope CA, they'll ship but they're pretty proud of their parts there.
timatoe is online now
post #3 of 7 Old 05-13-2012, 01:48 AM
NonRubicon
The CTO prevents vacuum from passing through the valve when the engine is cold, to prevent the EGR from operating and the emissions canister from purging. If the CTO were stuck open, I would expect the idle problem to also occur when the engine is cold, the EGR would operate too (which it shouldn't when cold). If the CTO were stuck closed, then the EGR and canister wouldn't function at all hot or cold. From what you described, it makes me suspect a problem with the canister. Some sort of vacuum leak with the purge signal line.
If you're looking for a new canister, just swap in a vacuum canister for a '90's 4.0L Wrangler/Cherokee. This canister will have the tank vent line, purge line, and purge signal line you need for the Howell conversion and won't require capping any ports. I put one in my YJ when my OEM canister went bad. Seemed to be a bit more snug of a fit than the OEM, but no problems otherwise.
FWIW, for any other folks that come across this post, the 4.0L canister can also be modified to work with carbed YJ's by drilling open the plugged port to hook up the carb vent line.
The OEM part number for the 4.0L canister should be 53030500. I got mine from rockauto.com
NonRubicon is offline
post #4 of 7 Old 05-13-2012, 10:46 AM Thread Starter
lower7
Thanks. I think i will go ahead and pick up a 4.0 canister and see if that fixes things.
lower7 is offline
post #5 of 7 Old 05-13-2012, 12:18 PM
timatoe
timatoe's Avatar
I think the 4.0 canister has one less port, but it should be the same port (or lack of) that you cap off with the Howell anyway.
post #6 of 7 Old 05-18-2012, 08:38 PM Thread Starter
lower7
Follow up: I got the new 4.0 canister from RockAuto yesterday. Installed this evening. Problem solved. Manifold vac was pulling through the evap canister and messing up my ported vac.
its running so quiet now that, i am hearing other issues.
Thanks for all your help!!!
John
lower7 is offline
post #7 of 7 Old 05-18-2012, 08:43 PM
superj
ha ha ha, badass its running great though!!
I don't feel like working on anything at this time so i sold my yj.
superj is offline
01 tj charcoal canister Pete814 TJ Wrangler Technical Forum 1 03-31-2012 07:44 PM
charcoal canister/vapor canister took a dump need help AmmitOsiris YJ Wrangler Technical Forum 5 12-29-2011 08:34 PM
Charcoal Canister in 98 TJ splitz TJ Wrangler Technical Forum 0 04-09-2007 02:09 PM
charcoal canister toates89 YJ Wrangler Technical Forum 12 06-23-2006 07:00 PM
Charcoal canister TSEJEEPERS YJ Wrangler Technical Forum 2 12-21-2004 01:42 PM
