backspacing?! - JeepForum.com
post #1 of 6 Old 06-11-2005, 11:54 AM Thread Starter
H2who
backspacing?!
what backspacing do i need to run 12.50's with no rub? I have 10.50's and they rub so i don't get the turning radius that I know the ole girl has.
H2who is offline
post #2 of 6 Old 06-11-2005, 12:01 PM
jeepin_6337
are those 10.50s on stock wheels? you're not going to be able to run 33s on stockers. my steelies (15x8) are at 4" of BS which i like. regardless of what size tire youre running though, it's easy to fix the rubbing against the front leaves. do a search for "steering stops."
1995 4.0, AX-15, NP231(SYE), double cardan D/S
4.10 D30/D44-Detroit, 3.5" Superlift
Foothill Offroad u-bolt flip, K&N drop-in
MORE no-lift greasables, 1" BL, 1990 rollbar
33x12.50 retreads/steelies, Herculined
AtoZ rockers, no sway/trac bars, 40mm "console"
jeepin_6337 is offline
post #3 of 6 Old 06-11-2005, 12:13 PM Thread Starter
H2who
how do you get the backspacing on... newby question but I don't know how it is installed. sorry for the dumb question
H2who is offline
post #4 of 6 Old 06-11-2005, 12:58 PM
jeepin_6337
again, if you would use the search feature at the top of the page you could answer these questions for yourself (it's all been asked before, i promise). BS refers to the distance (usually in inches) from the mounting surface on the inside of the rim to the outer lip of the rim. more BS means the rims will sit closer in towards the body of the jeep, less BS will put them further outside the flares. so, BS isn't a physical item you can install. you may be thinking of wheel spacers which allow you to move your wheels further outside of the flares, which are as easy to mount as removing/installing a tire.
post #5 of 6 Old 06-11-2005, 01:15 PM
Macabre
Macabre's Avatar
1990 XJ Cherokee
By buying wheels with the backspacing you want/need.
Like jeepin_6337 said, do a search. You'll find information aplenty.
1990 XJ, 2-door, 4.0, AW4, NP231, 3" lift, 32x11.5 Interco SSR's. 104,000 miles.
Macabre is offline
post #6 of 6 Old 06-11-2005, 05:48 PM
JOKER4INK
Im running 15x10 wheels with 3.75" backspacing. I am running 35x12.50 tires. I wouldnt go with less back spacing because the tires come pretty close (within about 1-2") to the front springs. they will stick out, so be prepared to get some wider flares. Also, if you go with less backspacing you may have clearance issues with the extended brake lines if you are lifted. Less backspacing is good though, the wheels tuck when articulating.
88 YJ...kinda. Clayton Hard Arms, V8, 1 tons running gear, twin sticked, Irok's, fuel cell, multi-colored
JOKER4INK is offline
Confused about backspacing and overall wheel size (What backspacing for a TJ?) uknowwho TJ Wrangler Technical Forum 21 10-03-2009 10:12 AM
90 YJ Backspacing? andrewbranch06 YJ Wrangler Technical Forum 4 11-30-2008 10:17 AM
backspacing? help Dead_Horse JK Wrangler Technical Forum 4 01-02-2008 11:20 AM
Backspacing tj01wrangler TJ Wrangler Technical Forum 9 05-25-2005 10:03 PM
Rim backspacing? Gritz TJ Wrangler Technical Forum 3 04-06-2005 02:39 PM
