Backfiring... - Page 9 - JeepForum.com
post #121 of 232 Old 07-18-2013, 09:30 PM
TSEJEEPERS
Originally Posted by C2tuck View Post
So is it a defective distributor for that year? Surely it hasn't been running this way for the PO...it has 120k miles on it...
I am thinking the PO swapped it.
My original distributor hold down prong broke off. I guess that is what you would call it. The two prongs that hold the distributor and keep it from turning. That is why I put a new one on. Maybe the same thing happen to the PO.
No not defective just the wrong part.
I may be wrong but it is worth a shot.
It will not cost you anything, heck you may be able to swap them in the parking lot of the parts store. If it does not work swap them back.
If Siva283 can find his spare it is from a 95 too.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #122 of 232 Old 07-19-2013, 05:09 AM
Siva283
I haven't foegotten. I got 3 storage units I am searching. Srill got one more to go. Since it wasn't where I thought it was.
Sent from my SPH-L300 using JeepForum
Ask me how I know...
Siva283 is offline
post #123 of 232 Old 07-19-2013, 02:58 PM
Siva283
I think I have located it Tuck I will know this evening. I realized I am an idiot. I am 99% sure I never took it off the old engine yet witch I didnt check. Its brand spanking new too. It was part of the trouble shooting process I never did get that engine started because it had a broken exhaust valve that punched a hole in the number 2 pistion. Before I learned this the dizzy was one thing that came up and I replaced it since the old one had 260,000 miles on it. So this one has about 15 mins of cranking on it and thats it. I just gotta remember to take my half inch wrench with me to the storage locker
Siva283 is offline
post #124 of 232 Old 07-20-2013, 01:50 PM Thread Starter
C2tuck
2014 JK Wrangler
Think oriellys will switch it out for a 95 model?
C2tuck is offline
post #125 of 232 Old 07-20-2013, 04:48 PM
Siva283
I cannot find that dizzy anywhere. It was not still hooked up to my old engine. I have looked everywhere.
Siva283 is offline
post #126 of 232 Old 07-20-2013, 06:53 PM Thread Starter
C2tuck
2014 JK Wrangler
That's fine. Thanks for looking tho. Do they just swap them out tho?
C2tuck is offline
post #127 of 232 Old 07-20-2013, 07:04 PM
Siva283
They should
Siva283 is offline
post #128 of 232 Old 07-20-2013, 09:02 PM
TSEJEEPERS
Worth a try.
Like I said it is a long shot, but it did work for me.
post #129 of 232 Old 07-24-2013, 12:52 PM
TSEJEEPERS
Did you ever get this figured out?
post #130 of 232 Old 07-24-2013, 12:58 PM
Siva283
If we dont hear back in the next day or so I would go with Yes the 95 dizzy solved it.
Siva283 is offline
post #131 of 232 Old 07-24-2013, 02:08 PM
squarelite
Ahhhhhhhhhhhhhh!!!!!!!!! Dizzy!!!!!!!!!! Nooooooo, I want to stab myself in my e-ears!!!!!!!!!
squarelite is offline
post #132 of 232 Old 07-24-2013, 03:16 PM
Siva283
Who are you? I am guessing you can't ahoot straight
Siva283 is offline
post #133 of 232 Old 07-24-2013, 09:57 PM Thread Starter
C2tuck
2014 JK Wrangler
Ok. So finally for the axle back in and took it for a spin. Drive it about 30 miles and it ran great for about half of it...then got worse and worse on the way back home. To the point that I was in second gear on a flat road I'll try to get the distributor swapped out this weekend and hopefully that will fix it...
So far I've done the following:
New plugs
New wires
New cap and rotor
New distributor (93) model
New coil
New air filter
New fuel filter
Any ideas besides putting a 95 model distributor in it?
C2tuck is offline
post #134 of 232 Old 07-24-2013, 10:15 PM Thread Starter
C2tuck
2014 JK Wrangler
Sorry siva...been busy as hell lately with work and projects around the house...have had time to think, much less work on the jeep...
C2tuck is offline
post #135 of 232 Old 07-24-2013, 10:40 PM
mike_breaker_5
it may not be the cats... but my money still sits on the exhaust being jewed up somewhere.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
