Backfiring... - Page 15 - JeepForum.com
post #211 of 232 Old 08-31-2013, 08:55 PM Thread Starter
C2tuck
2014 JK Wrangler
Ok...checked the codes. Only gives me a 12 and a 55...
C2tuck is offline
post #212 of 232 Old 08-31-2013, 11:00 PM
mike_breaker_5
ok... so...
after being completely stumped i asked another jeeper i know about an issue like yours... his reply... "change the whole dist" after asking why that would make a difference his reply... " i had exactly the same issue, when i grabbed the dist cap i could feel rubbing somewhere inside the block". it would seem that the bearing can wearout and cause an issue like this after warmup as the dist itself is getting tweaked from heat due to a wore out bearing or some jazz after heatup.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #213 of 232 Old 09-01-2013, 07:27 AM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
No code 33? That is an AC related code which comes up even if there is no AC.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #214 of 232 Old 09-07-2013, 09:10 PM Thread Starter
C2tuck
2014 JK Wrangler
Nope...no 33 code. I've been in phone contact with another member on here and at this point we are both stumped...
I went ahead and changed the o2 sensor and the MAT sensor and still same issue. I also checked the fuel pressure and it is fine...
Mike, I've ready changed everything in the ignition system. Dist and all.
C2tuck is offline
post #215 of 232 Old 09-09-2013, 04:22 AM
Que89YJ
Chuck I really think the fact you are not seeing code 33 that there is something going on with the ecu. I am really hesitant to tell you to replace something I can't figure out how it failed our how to test. I have never seen a ECU not throw the 33 code sui right away it makes me suspicious. I wish there was a jeep guy close by to do a swap and try out their ecu.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is online now
post #216 of 232 Old 09-09-2013, 07:56 AM
TSEJEEPERS
Did you ever try the 94 distributer?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #217 of 232 Old 09-09-2013, 08:04 AM
Que89YJ
TSEJEEPERS what is the difference on a 94/95 distributor? I had him disconnect the O2 sensor and run it and it still messed up after 15 minutes. The key is that it happens after warming up. When he pulls over and lets it sit then restars its good for a few minutes and then starts the same thing again.
post #218 of 232 Old 09-09-2013, 10:33 AM Thread Starter
C2tuck
2014 JK Wrangler
I'll disconnect the battery tonight and recheck the codes again. If there is still no 33 code then I'll try and find one around here to borrow or just buy another one.
C2tuck is offline
post #219 of 232 Old 09-09-2013, 10:36 AM
Que89YJ
Try this guy. If it ends up not fixing it the price is cheap enough that you can get all your money back:
http://www.greatlakes4x4.com/showthread.php?t=255801
post #220 of 232 Old 09-09-2013, 04:18 PM Thread Starter
C2tuck
2014 JK Wrangler
You have his # or do I need to create an account on that forum?
C2tuck is offline
post #221 of 232 Old 09-09-2013, 04:43 PM
Que89YJ
Try to pm him if not then it's free to join. I have been a member for a while now and I don't remember.
Fault codes:
No Start:
post #222 of 232 Old 10-23-2013, 05:21 PM
dirtynuts
hey guys new on here but not to this problem I have a 92 2.5 wrangler with same problem and ive replaced all sensor,o2,distributor,wires,plugs,fuelpump and pickup,tank,fuel lines,fuel pressure regulator and all vacuum lines all new exaust including cat and mines doing the exact same thing. runs good for a few minutes then starts backfiring and loosing power. I have good idle and good full throttle but no in between pedal. if im in the mid range its backfiring. well after a lot of messing around I put a fuel pressure guage on it and when its backfiring its loosing fuel pressure. I can cut it off and back on and the pressures fine for a few minutes then it starts to **** up and loose pressure again I cant figure it out I ordered a computer for it today and it will be here in three days hopefully it will fix it
dirtynuts is offline
post #223 of 232 Old 10-23-2013, 06:31 PM
Que89YJ
It's not the ecu. Pm sent. Call.
Fault codes:
No Start:
post #224 of 232 Old 10-29-2013, 05:11 PM
dirtynuts
so I put another iac on mine and it cleared it up not the check engine lights on and its for the 02 sensor but ive put 4 on it with no luck at it clearing
post #225 of 232 Old 10-30-2013, 08:17 AM
Que89YJ
Do you still have the o2 fault?
Fault codes:
No Start:
