Backfiring... - JeepForum.com
post #1 of 232 Old 06-27-2013, 07:07 PM Thread Starter
C2tuck
2014 JK Wrangler
Backfiring...
Ok, so I've always wanted a wrangler and I finally got one. It's a 93 2.5 5spd. It's not perfect but I always like a project! I already plan on swapping a 4.0 in it and have already bought one. I'm sure ill be asking tons of questions when I get around to doing that
But my post for today is about it running bad. It runs fine until its warmed up and then it starts bogging down and backfiring bad! I'm talking downshifting to 2nd on the highway to get it to move. Never overheated or got close to being hot. I've already changed the plugs, wires, dist cap, rotor, oil and filter, and air filter. It was pretty nasty underwood so I cleaned her up a bit.
Any ideas?
C2tuck is offline
post #2 of 232 Old 06-27-2013, 07:33 PM
idaholtby
Congrats on your first Jeep and welcome to the forum! First and foremost check for codes to see if any are stored. This info may help to pinpoint your issue.
idaholtby is offline
post #3 of 232 Old 06-27-2013, 08:01 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Any ideas?
Your emissions/fuel/timing etc. are controlled by the ECM. When the engine is cold are running in open loop mode and on the factory presets. Once the engine gets up to temp you go into closed loop mode and run on learned memory BUT you sensors are always checking those numbers. You have something that is out of the factory parameters.
idaholtby mentions checking for any stored codes. That is step #1. Does your Check Engine Light go on when you start your engine? If not someone pulled the bulb. You have to check for stored codes even though the CEL may not be lit up. If it does light up check your DTC's (trouble code by doing the following:
Post #3;
http://www.jeepforum.com/forum/f12/e...eading-311539/
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #4 of 232 Old 06-27-2013, 10:34 PM
04WJny
1987 YJ Wrangler
Does it backfire under load or at idle after its warm?
What size are your tires? stock? My engine is different than yours, but I find that when sometimes im on the highway and im trying to accelerate, sometimes i backfire because i put my jeep under too much load, especially with stock 3.07 gears lol.
Have you checked your vacuum lines? most importantly your vacuum advance on your distributer. You can use some carb cleaner and spray around the vacuum lines when your engine is running, if your RPM changes you have a vacuum leak.
Good luck with your new Jeep and welcome!
2004 WJ I6 4.0L DD
1987 YJ I6 4.2L Weber 34 DGEC carb, 4in RC, Custom 1 inch BL,Custom Steering box skid, homemade rear bumper with tire carrier, 33x12.5x15 KM2's on
Cragar Soft 8's, and a few other things
In the process of putting in an 8.8, d30, 4.10's, SOA, and a homemade belly up skid
04WJny is offline
post #5 of 232 Old 06-28-2013, 08:33 AM
mike_breaker_5
plugged cat or muffler.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #6 of 232 Old 06-28-2013, 10:28 AM
Siva283
^^^^This, Usually a bad 02 sensor running rich will cause the cat to melt. So if you do in fact discover its the cat change your 02 sensor.
Ask me how I know...
Siva283 is offline
post #7 of 232 Old 06-28-2013, 11:38 AM
Kuntryboy816
Kuntryboy816's Avatar
Congratulations on your first Wrangler!
What you are experiencing is called Testeronic Deflation. You aren't actually hearing a backfire but the sound of the afterburners failing to ignite which is pretty common with a 4-banger Wrangler. You have the downshifting part correct but I'd bet the PO didn't remember to tell you the last 2 crucial elements that will enable your Jeep to perform correctly... giving you that white-knuckled, nut-tingling euphoric rush of adrenaline that is called JEEP! First, when entering the highway, you MUST have Kenny Loggins' "Danger Zone" playing on the stereo as loudly as possible w/o distorting the sound. Secondly, when you downshift into 2nd gear you must quote (verbatum and in an excited manly voice), "It's time to kick the tires and light the fires!" The second you finish the quote, downshift into 1st, throttle to the floor and hang on!
Originally Posted by 14Sport View Post
Until you know exactly what is underneath the, well, not really sure what to call them...mistakes...it's hard to come up with a plan of action.
Kuntryboy816 is offline
post #8 of 232 Old 06-28-2013, 11:41 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
I agree that a plugged cat/muffler or crushed tailpipe could also be the OP's problem also but seeing if there are any stored codes or that his CEL even lights up will help us help him.
post #9 of 232 Old 06-28-2013, 02:42 PM
ForestJeep89
Post #3;
^^^^ this== remember always do the simplest things first cuz it usually saves a person a lot of grief...
ForestJeep89 is offline
post #10 of 232 Old 06-28-2013, 02:48 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Naw, you only get that when you get married...or is that testeronic separation...I forget already.....
post #11 of 232 Old 06-29-2013, 09:26 AM Thread Starter
C2tuck
2014 JK Wrangler
Thanks for all the reply's guys. I've been busy at work and haven't had a chance to reply.
1. The check engine light does NOT come on when I start it up...so I guess I'll have to check the bulb.
2. I'm about 30 miles from the closest auto parts store so I'm kinda hesitant to drive it that far to check the codes. Unless there is a trick that doesn't require a code reader.
3. The exhaust sounds like ****. It rattles and is pretty rusted. Can't see and obvious holes in it but I wouldn't be surprised if the car or muffler where clogged. If so would it not affect performance while engine is cold?
I don't really want to redo the exhaust now before I swap the motor in a few months...unless I can use the same exhaust with the I6.
Oh...and ain't no lightin' tires on this thing. It sees a hill and slows down!
C2tuck is offline
post #12 of 232 Old 06-29-2013, 10:19 AM
mike_breaker_5
if the exhaust is rattling i say it's definitely a plugged cat. the ceramic cake comes loose and gets lodged in there sideways. i had exactly this happen to me on my way to work one day.
post #13 of 232 Old 06-29-2013, 12:27 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
If the CEL had a good bulb that did not light up when you hit the ignition your Jeep will not start UNLESS all the emission's equipment has been disabled.
Check the CEL bulb. I'll bet it is pulled. Steal another bulb out of the dash for the time being and stick it in the CEL bulb socket. It never blows since it is quite heavy duty. Once it is replaced go to this thread post #3 I think it explains how you can read the codes;
Then for the codes go to this thread post #2
http://www.jeepforum.com/forum/f12/r...estion-723082/
post #14 of 232 Old 06-29-2013, 12:35 PM
Masta-P
My 93 4 banger had similar problems a few months ago. New cat straightened it out and if I remember correctly same part number for the 4 or 6.
Masta-P is offline
post #15 of 232 Old 06-29-2013, 12:56 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
The cat converter can often be the problem.
But the first issue is the OP's YJ starts but it show no CEL during startup.....I smell 'cover up' by the PO. You know the drill....no CEL..... nooooooooo proooooblems!!
And bet is there is a DTC that will show up when the OP gets the CEL bulb to light up. From there maybe we can figure out what is going on without throwing a bunch of parts at this YJ.
