back up lights - JeepForum.com
post #1 of 3 Old 12-05-2001, 10:33 AM Thread Starter
funerald55
back up lights
back up lights don't come on, check fuse and bulbs,all good where is switch,help
funerald55 is offline
post #2 of 3 Old 12-05-2001, 10:51 AM
glm 87 wrangler
Well my backup lights dont work ether.Mine is the neutral start switch on the automatic tranny but if you have a manual tranny then there should be a plug looking thing with a wire running to it.On an auto transmission it is on the driverside on the manual trans dont
know which side.but look for wires you, should find something around there that may look like a plug type switch. hope this helps..,
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #3 of 3 Old 12-05-2001, 10:54 AM
glm 87 wrangler
the switch would be on the transmission. sorry lift that out!!
AX-5 & Back up lights MOOG TJ Wrangler Technical Forum 1 04-25-2009 01:03 PM
fog lights and rear back-up lights hoot20 TJ Wrangler Technical Forum 2 01-11-2009 04:00 PM
Back up lights hispeed YJ Wrangler Technical Forum 3 01-04-2008 10:41 AM
Back-up Lights...and need help Nite-Krawlers TJ Wrangler Technical Forum 10 06-04-2007 08:44 AM
