Back up Lamp Switch - JeepForum.com
post #1 of 15 Old 02-22-2009, 10:02 PM Thread Starter
losfelizwheelz
Back up Lamp Switch
Hello all:
On my transmission, I've got one electrical connection leading back to the fuse block. Anybody know which of these wires should connect to the back up lamp switch? I'll post pics of the wires tomorrow.
losfelizwheelz is offline
post #2 of 15 Old 02-22-2009, 10:03 PM Thread Starter
losfelizwheelz
sorry, that's the 5 speed manual tranny
post #3 of 15 Old 02-23-2009, 11:15 AM
timatoe
timatoe's Avatar
The back up switch is mounted to the transmission, I believe it's about 1/2 to 3/4 the way back toward the top on the passenger side.
timatoe is online now
post #4 of 15 Old 02-23-2009, 08:06 PM
kloppk
Originally Posted by losfelizwheelz View Post
Hello all:
The wire between the backup switch and the fuze block should be Yellow/Black.
The wire between the backup switch and the backup lights should be Brown/Green.
kloppk is offline
post #5 of 15 Old 02-23-2009, 08:11 PM Thread Starter
losfelizwheelz
many garcias to you both
post #6 of 15 Old 02-23-2009, 08:39 PM
jbeebe
i'm sure they appreciate the many garcias!
jbeebe is offline
post #7 of 15 Old 02-23-2009, 09:14 PM Thread Starter
losfelizwheelz
least I didn't say 'manny garcias to you both.'
post #8 of 15 Old 02-23-2009, 10:18 PM
jameskehler
My backup switch is bad also. It is located on the drivers side of th POS Peugot. I buypassed the conector and the light came on so I know the switch is bad. Now I just have to order the switch. Any idea where to find the switch? Sorry for hijacking your thread losfelizwheelz.
/l ,[___],
l--L-@lllllll@-
( ) ( )−Ω−)
jameskehler is offline
post #9 of 15 Old 02-24-2009, 06:59 AM
kloppk
The part number of the backup switch is 53004522.
You can get it from a number of places.
For example... http://www.quadratec.com/products/52449_0254.htm
or http://www.trailquest.com/electrical/switches.shtml
or http://www.jeep4x4center.com/product...umber=53004522
kloppk is offline
post #10 of 15 Old 02-24-2009, 07:02 AM
yamaguy01
Time to swap the tranny! J/K but that Peugot is a POS, I couldn't wait to loose mine!
Dave
NRA Life member
Square Headlights group member #222
Armed Forces Jeeps group member #65
United States Air Force group member #12
Guns and Jeeps group member #10
Ron Paul Jeepers group member #7
yamaguy01 is offline
post #11 of 15 Old 02-25-2009, 02:19 PM Thread Starter
losfelizwheelz
I know, man...the eighties saw some weird engineering choices.
The Jeep Wrangler...an iconic symbol of American industrial capacity, love of individual freedom, and hegemonic military dominance...now with a French transmission.
As a born and raised Detroiter, I hang my head in shame...
post #12 of 15 Old 02-25-2009, 02:22 PM
firefighter315
.....okay, I'm done....
My YJ Build Thread
firefighter315 is offline
post #13 of 15 Old 02-25-2009, 05:38 PM
xeroid81
JEEP was bought by Renault in the old days. Not sure how long they owned it before they dumped it. Maybe that's where they found the Peugot tranny. Not sure about it though.
xeroid81 is offline
post #14 of 15 Old 02-25-2009, 08:08 PM Thread Starter
losfelizwheelz
SO...I just hooked it up, and no back up lamps. I know my harness is good, cuz it's a new harness from painless. The colors match up (sort of) with a yellow/black wire, a brown/white wire, and two grounds (black/white to solenoid, black to main ground).
Even with it all wired, I got nothin...great. Just farking great.
post #15 of 15 Old 02-25-2009, 09:30 PM
firefighter315
When I did my flush mount LEDs, I just went the simple route and mounted two 55W halogens out of the way. To avoid the headache you are experiencing and dealing with finding a place for a relay and such, I just wired those two in their own circuit to my aux. fuse panel that I already had installed under the hood for accessories. Now I just flip the switch before backing at night (it's right above my shifter on the dash). It also comes in handy as auxillary lighting behind the Jeep when needed.....Common set up, I know, but it works great for me!
My YJ Build Thread
4WD Indicator Lamp Switch???? louieberner YJ Wrangler Technical Forum 2 12-29-2009 08:43 PM
Fog Lamp Switch Terminals Spank TJ Wrangler Technical Forum 3 11-28-2009 10:16 PM
fog lamp switch pinout. ancestralworm TJ Wrangler Technical Forum 5 03-11-2008 02:27 PM
Overdrive switch lamp FmrVette TJ Wrangler Technical Forum 3 06-26-2007 09:54 PM
Fog Lamp Switch mossimo19 TJ Wrangler Technical Forum 3 08-11-2004 07:48 PM
