Back from Afghanistan and need help! - JeepForum.com
post #1 of 10 Old 08-16-2011, 08:38 PM Thread Starter
thunderstar99
I just got back from Afghanistan and installed my 3 1/2 inch lift with 1 inch shackles and was wondering if I needed to upgrade my rear driveshaft to make it longer with that much lift. Thanks, William
thunderstar99 is offline
post #2 of 10 Old 08-16-2011, 08:44 PM
dillonjm
2013 WK
Welcome back bro.
The answer is: it depends. If you're not getting any driveline vibrations after the install at highway speeds then you don't need to worry about it.
Did your kit have a t-case skid drop with it?
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #3 of 10 Old 08-16-2011, 08:54 PM
Dlambright
Welcome home & thank you for your service! To answer your question, no you dont. You may need to shim the pinion up a bit if you get some vibes, but the driveshaft is fine with that much lift. You used a t-case drop kit with the lift right?
Dlambright is offline
post #4 of 10 Old 08-16-2011, 10:39 PM Thread Starter
thunderstar99
Yes I used the t-case drop kit and I also got it all put back together and the rear shackles are facing the wrong direction so I have to go back and take care of that. I had never done anything that big before and was surprised how easy it actually was. Had to replace a lot of other stuff because the po didnt maintain it mechanically. I will try to put some pics up. Thanks for the info I really appreciate it as this is my first jeep and first build and I think Im addicted.
post #5 of 10 Old 08-16-2011, 10:48 PM Thread Starter
thunderstar99
post #6 of 10 Old 08-16-2011, 10:52 PM
DavidHoover
That's one of the best looking YJ's i've seen in a while!!!
DavidHoover is offline
post #7 of 10 Old 08-17-2011, 08:52 AM Thread Starter
thunderstar99
Still have to retorque everything after it settles and then touch up on the paint to help with the rust and then on to the next part of the build.
post #8 of 10 Old 08-17-2011, 11:13 AM
dadstoy
Torque your shackle bolts to 45ft/lbs or so. Flexes better and rides better.
dadstoy is offline
post #9 of 10 Old 08-17-2011, 11:34 AM
Alfons
Have a look at the slip yoke and see how far out the lift has pulled it, you'll see some clean steel where that part of the yoke was behind the seal & the farther out it is, the less connection there will be between the yoke and the output shaft. The drive shaft isn't affected by the body lift & with only a 1" shackle lift, the shaft extension shouldn't be bad, so you probably don't need to do anything. Be careful about the t-case drop kit, this can sometimes change the U-joint angles to the point of causing vibration - there are a number of pictures around on what the angles should look like, but ideally the t-case and pinion u-joint angles should be the same (unless you have a double-cardan joint at the t-case).
Alfons is offline
post #10 of 10 Old 08-17-2011, 11:45 AM
dtn8tr
Look at your front shackles...they are backwards. The rears are good. The front should have the short side of the shackle attached to the frame and the point should point into the center of the vehicle like this... > <, front and rear.
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
Jeep Wrangler Rubicon Driving Through Afghanistan Mountains! strokera4 Wrangler General Discussion 7 01-06-2011 01:28 AM
Returning from Afghanistan, need help spending $ Washi TJ Wrangler Technical Forum 22 04-24-2010 06:28 PM
Needing a little bit of help in Afghanistan OEFsahara YJ Wrangler Technical Forum 4 11-30-2008 08:24 AM
Back From Afghanistan JSimmons Wrangler General Discussion 27 06-10-2008 08:43 AM
