BA10 to AX15 swap question - JeepForum.com
post #1 of 11 Old 05-20-2009, 03:53 PM Thread Starter
88YJtoCJ
Rig, 88 YJ, AMC 258 Straight 6, 4.2L, BA10, 21 spline NP231.
Getting rid of the crappy BA10.
I bought an AX15 (getting an external slave bellhousing, clutch master and slave cylinders).
Anything I should be changing out as well? Here is my list so far
23 spline NP231 & seals
Check Clutch Plate
Check Flywheel for resurface etc
Bellhousing Front Transmission Oil Seal
Transmission to TC oil seal
Check Transmission shaft size for pilot bushing
replace pilot bushing from .565" to .750" pilot bushing if needed (anyone got a part number for this guy [the .750"] just in case?)
I heard something like a 76 CJ pilot bushing works? whats the exact year / engine combo?
Thanks for the help, cheers!
88YJtoCJ is offline
post #2 of 11 Old 05-20-2009, 04:42 PM
levergun
1979 CJ5
Looks like you got it covered. My tranny was from a 90 so the bushing was the same but if you get a bushing the same year as your tranny you should be good. Also when you got the tranny boot off cut you floor back a little. I had some problems with mine not going fully into 2nd and popping out.
I've heard that the external slave needs a different master to work properly??? Something about the stroke being different??? I would have liked to have upgraded to the external but I got a good deal on the 90 tranny.
Also do you have a new mount??? The mounts are totally different. I just welded up an adapter plate for mine but the mounts are different. The BA/10 has 2 bolt holes that are much closer together than the AX15.
1979 CJ5 408 AMC dana 60/14b, T18, d300, PSC hydro assist
1948 Willys CJ2a LS 4.8/sm465 scout 44's
levergun is offline
post #3 of 11 Old 05-20-2009, 05:03 PM Thread Starter
88YJtoCJ
ah good call, transmission mount
My floor has already had some "modifications" the plates are held in with screws that I put in the drill and just tapped it down. So that won't be an issue... tin-snips are your friend, as is the angle grinder.
My crossmember already has the "location" for the AX15.
yes the External slave needs a new master cylinder. The Bellhousing that I bought comes with slave and master cylinder and the lines connecting. Can just line the master cylinder up (have to redrill bottom mounting hole) and the rest is cake.
88YJtoCJ is offline
post #4 of 11 Old 05-20-2009, 05:09 PM
Bridgeman
Advance adapters can hook you up with the pilot bushing and the mounting plates for your tranny and for your t-case shift linkage. The mounting plates make this swap alot easier. If you don't mind spending some cash you can also get a stainless line to run from your master cylinder to the slave also from advance adapters. Your master cylinder is also fine to run the slave, no need to swap. I have been running the stock master for some time with no problems. The guys at advance adapters are very helpful(1-800-350-2223)
Bridgeman is offline
post #5 of 11 Old 05-20-2009, 05:15 PM
5-90
5-90's Avatar
1988 XJ Cherokee
I went through four of the BA-10's in my 88XJ before I finally got an AX-15...
The pilot bushing you're looking for is an early 1970's CJ with the AMC V8-304 and three-speed manual.
I know this is an XJ-centric thread, but you should still find plenty of useful information in here...
http://www.naxja.org/forum/showthread.php?t=70388
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #6 of 11 Old 05-20-2009, 10:24 PM Thread Starter
88YJtoCJ
As for the np231, I can use an NP231 from a 97 Jeep Cherokee with 4.0L engine right?
Doesn't matter that it was an automatic with an electric shift does it, since the Arm should still be there that I can just attach my linkage to my manual shifter?
88YJtoCJ is offline
post #7 of 11 Old 05-20-2009, 11:12 PM Thread Starter
88YJtoCJ
bump, need to know if buying a cherokee np231 will work or not... preferably before I buy it. Thanks
88YJtoCJ is offline
post #8 of 11 Old 05-20-2009, 11:20 PM
5-90
5-90's Avatar
1988 XJ Cherokee
It should not.
As far as the clocking angle of the thing (the "Universal" is clocked flatter than the XJ/MJ/ZJ/...) that is done by the transfer case adapter on the transmission end, not the transfer case mounting studs. So even with the case being from an XJ, you should have no trouble.
Just make sure you can adapt the electric shift to the mechanical shift easily (I didn't know any XJs came with an electric shift transfer case...?)
5-90 is offline
post #9 of 11 Old 05-20-2009, 11:27 PM Thread Starter
88YJtoCJ
oh is that it should not work, or it should not matter that its auto/manual?
I am looking at a 97 6 cylinder cherokee NP231, my TC is a 21 spline and is thrashed, I need a 23 spline and figured this should work for my 88 YJ / AX15 swap
88YJtoCJ is offline
post #10 of 11 Old 05-21-2009, 12:02 AM Thread Starter
88YJtoCJ
bump, guess I will buy it and hope it works only about 20 min left on it (auction)
88YJtoCJ is offline
post #11 of 11 Old 05-21-2009, 01:11 AM
5-90
5-90's Avatar
1988 XJ Cherokee
Auto/manual transmission doesn't matter. I'd thought you were saying that the transfer case itself was an electric shift job, which is why I was confused. If it's just a standard 23-spline NP231, you're fine.
5-90 is offline
ba10 to ax15 swap problem-engine wont stay running-stops abruptly saharajeepman YJ Wrangler Technical Forum 1 08-08-2008 08:33 PM
BA10 to AX15 clutch question jukeyard YJ Wrangler Technical Forum 2 07-14-2008 03:25 PM
what modifications are needed to swap Ba10 for AX15 BA-YJ YJ Wrangler Technical Forum 13 06-23-2008 10:16 AM
Pros & Cons To Swap A Ax15 Or Nv3555 What It Is Better To Take Out Ba10/5 Fed YJ Wrangler Technical Forum 3 10-02-2007 07:00 PM
BA10 to AX15 swap? 1NastyZ06 YJ Wrangler Technical Forum 5 01-09-2006 02:48 PM
