ba10 to ax15 swap problem-engine wont stay running-stops abruptly - JeepForum.com
post #1 of 2 Old 08-08-2008, 08:27 PM Thread Starter
saharajeepman
i am doing a ba10 to ax15 swap. when i turned the key for the first time, it would only crank once or twice. i figured that the battery was dead from sitting for awhile, so i bought a new one. after i put the new one in- i got it to crank over enough to start it, but that was after about two minutes of intermittent attempts. right after i got it to start, it would immediately die. i got it to start again and tried to rev it up a couple of times, but the second i let my foot off the gas it would die again. the strangest part is that it isnt shutting off like an engine normally would - in a smooth manner. its an abrupt stop, as if something is binding up. this happens whether i have the clutch in or not. the ax15 came out of a 93. i bought a new internal slave and master for the 93 and bled the system properly. any ideas?
'89 Sahara 4.2 258 Upstate, NY
31x10.5 BFG All Terrain, 470 cfm Holley Off-Road Avenger, Nutter Bypass,
RE 2.5, Currie Shackles front and boomerang rear
TJ front driveshaft, SYE, Tom Woods rear driveshaft, Posi-lok, AX-15 swap.
saharajeepman is offline
post #2 of 2 Old 08-08-2008, 08:33 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I would probably pull all the spark plugs out & try turning the engine over manually, with a ratchet & socket on the crank pulley. If it's really difficult to do (with the plugs out) I would think that something is binding up, as you mentioned.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
wont stay running when engine is cold shoeshard YJ Wrangler Technical Forum 1 02-10-2010 04:36 PM
BA10 to AX15 swap question 88YJtoCJ YJ Wrangler Technical Forum 10 05-21-2009 01:11 AM
Jeep wont stay running, keeps stalling until engine has warmed up subzeroedj TJ Wrangler Technical Forum 5 12-06-2008 01:54 PM
what modifications are needed to swap Ba10 for AX15 BA-YJ YJ Wrangler Technical Forum 13 06-23-2008 10:16 AM
BA10 to AX15 swap? 1NastyZ06 YJ Wrangler Technical Forum 5 01-09-2006 02:48 PM
