BA10-5 shifter removal - JeepForum.com
post #1 of 6 Old 04-28-2013, 12:18 PM Thread Starter
dtn8tr
I looked and didn't find a clear explanation...I am looking to seperate the shifter handle from the stub on my '88 YJ. What is the easiest way to do this or do I HAVE to remove the whole thing from the tranny?
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #2 of 6 Old 04-28-2013, 12:48 PM
Berniebikes
remove the plates off the top, pull up the rubber underneath. There are three bolts that hold the shift lever in place. remove them and lift straight out.
Berniebikes is offline
post #3 of 6 Old 04-28-2013, 11:18 PM Thread Starter
dtn8tr
That's what I ended up doing but I was trying to find a way to seperate the stub shaft from the shifter. Thanks.
dtn8tr is offline
post #4 of 6 Old 05-01-2013, 11:44 AM
jkilmer83
1983 CJ7
give a bump i need to do the same thing
1987 yj w/(new)258 .060 over comp cam mc 2150 carb
1989 yj sold
1983 cj7 w/258 t5 dana 300 45k original
mc2100 carb
You just can't fix stupid!!!
jkilmer83 is offline
post #5 of 6 Old 05-01-2013, 09:48 PM Thread Starter
dtn8tr
As stated, I ended up removing the retainer ring but after getting it out it appears that it should separate similar to the t/c shifter.
dtn8tr is offline
post #6 of 6 Old 05-01-2013, 11:49 PM
5-90
5-90's Avatar
1988 XJ Cherokee
Theoretically, it should separate at a "knuckle" above the shift tower cover.
But, I've always found it far easier to just pull the tower and stuff a CLEAN rag down the hole to keep crud out. As mentioned - three screws, and it's out.
Problem. Solved!
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
