Ba 10 - JeepForum.com
post #1 of 20 Old 02-23-2010, 11:49 AM Thread Starter
bmxer0122
1987 YJ Wrangler
Ba 10
Hey my clutch has gone bad in my Ba/10 trans. Online a new clutch kit runs around $350!!!!! Is there any other option for me, ie upgrade to a better trans that i could find cheaper(same price or a lil higher even) in a junkyard? It pains me to dump almost $400 into a junky trans...
Dave
bmxer0122 is offline
post #2 of 20 Old 02-23-2010, 11:50 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
You can do an AX-15 Trans/tcase swap for around that price if you get a good deal on the trans.
The part that gets hard is the BA-10 tcase setup is 21 spline and the AX-15 is 23 spline.
Hit the FAQ, there is a few writeups on BA-10 swaps to better trans.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 20 Old 02-23-2010, 11:53 AM
RikRotorhead
Autozone has the complete kit, clutch, pressure plate, slave cylinder, and pilot bearing for $160. PepBoys has it for $169. NAPA also carries it, but I don't remember the price.
And the BA10/5 will last you a long time if you don't abuse it and change the gear oil in it every 50K miles.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #4 of 20 Old 02-23-2010, 11:54 AM
rustywrangler
This is also true.
post #5 of 20 Old 02-23-2010, 12:03 PM
Douglas S.
Blech, dump the BA if you can. Mine blew at about 140k kilometers, on stock tires too.
1991 Land Cruiser HDJ81
Douglas S. is offline
post #6 of 20 Old 02-23-2010, 12:16 PM
rap169
i have a good clutch flywheel and pressureplate i can sell ya out of an 88 ba/10. It worked well before i tore it down, doin the ax15 upgrade so dont need this
rap169 is offline
post #7 of 20 Old 02-23-2010, 12:45 PM Thread Starter
bmxer0122
1987 YJ Wrangler
well my ba/10 has over 250,000 miles on it and seems to be taking the abuse ok. i am defiantely going to look into that pepboys/autozone clutch kit b/c i dont mind the 160. jcwhitney, summitracing, and quadratec's kits were all well over that price... if i were to find an ax15 couldnt i just take the tcase that is bolted up to it or will that not work out well?
post #8 of 20 Old 02-23-2010, 01:00 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
The BA10/5 has a 21 spline output shaft where the AX-15 has a stronger 23 spline output shaft. You can reuse the transfer case if you change the input shaft to a 23 spline.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #9 of 20 Old 02-23-2010, 01:02 PM
rustywrangler
Best case, least amount of work really, you would get the trans and tcase together.
post #10 of 20 Old 02-23-2010, 01:22 PM Thread Starter
bmxer0122
1987 YJ Wrangler
awesome! Thank you guys for all the info/ advice! im gonna do my homework now and figure otu which im going to do to get my jeep back on the road in no time!!!!
post #11 of 20 Old 02-23-2010, 02:03 PM
RikRotorhead
Change the gear oil in the transfer case, and the ATF Dextron III in the t-case while you have them out.
RJC#512
post #12 of 20 Old 02-23-2010, 03:45 PM Thread Starter
bmxer0122
1987 YJ Wrangler
thanks ill be sure to do that while i have it torn down!
post #13 of 20 Old 02-23-2010, 04:06 PM
bigorangeyj
Not to hijack the thread, but can anyone tell me why mine won't stay in reverse. As soon as I start letting out the clutch it pops out and I have to force it to stay in. I can hear and feel it popping, and grinding if that helps. Thanks for any help, Jon.
bigorangeyj is offline
post #14 of 20 Old 02-23-2010, 04:53 PM
5-90
5-90's Avatar
1988 XJ Cherokee
The friction parts for the BA-10 and AX-15 are exactly the same. The BA-10 throwout bearing may be used with the 1988.5-1993 AX-15i (internal slave) without incident, but you'll need to swap hydraulics to use a 1994-1999 AX-15e (external slave.)
Apparently, the input pilot on the AX-15i is the same OD as the BA-10, but the AX-15e has a larger input and requires a different bushing (early 1970's CJ w/V8-304 and three-speed.)
I've certainly never paid anything over $150 for a clutch kit for my 88 - whether I was putting it in front of a replacement BA-10 (I was there anyhow,) or putting it in front of my AX-15. Where are you shopping?
Granted, I did get the replacement BA-10s for the asking. Their only saving grace.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #15 of 20 Old 02-23-2010, 05:15 PM Thread Starter
bmxer0122
1987 YJ Wrangler
