ba 10/5 Question? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > ba 10/5 Question?
Attention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONSBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiBushed Sleeves & Poly Bushings!
Unread 10-21-2013, 05:14 PM   #1
rtillery34
1987 YJ Wrangler
ba 10/5 Question?
Are 87 and 89 ba 10/5 trannys interchangeable? Any modes I should know about?
rtillery34 is offline   Reply With Quote
Unread 10-21-2013, 05:28 PM   #2
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Yes they are a direct swap, however I would swap in a ax15 instead of the ba10
'89 YJ The Smurf Build Thread
'99 XJ Black Betty Build Thread
Tom95YJ is offline   Reply With Quote
Unread 10-21-2013, 07:27 PM   #3
rtillery34
1987 YJ Wrangler
Thanks Tom! Do you know if the 89 ba have a 21 or 23 output spline? I would and want the ax tranny but im getting the newer ba with half the miles for only $150!
Unread 10-21-2013, 07:33 PM   #4
irnmadn88
http://www.novak-adapt.com/knowledge/ba10_5.htm
And it is not really worth it to put in another Peugeot.
But what do I know, I put in two AX-15's in my last YJ after scrapping that POS BA10/5...
irnmadn88 is online now   Reply With Quote
Unread 10-21-2013, 09:07 PM   #5
5-90
1988 XJ Cherokee
Direct exchange, all BA-10s will have a 21-sp output. All AX-15s will have a 23-sp output, and swapping in an AX-15 is a bit more involved (but well worth the trouble.)
Go to www.naxja.org, and look for "Let this be THE Peugeot to AX-15 Swap Thread," I think it's called.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline   Reply With Quote
Unread 10-21-2013, 09:09 PM   #6
5-90
1988 XJ Cherokee
It's not - the only reason I put four of those damned things in my 88 was because I could get 'em just for the goin' and pickin' them up.
Yep - I put FOUR in, meaning I went through FIVE. All failed the same way - first and second gear stripped (at a minimum.)
Why? Because that gearbox was designed for the Peugeot 505 - half the engine displacement, 1,000# less kerb weight, 2/3 of the torque output, and the internals are too hard to be useful in this application ("hard" for steel is "strong" - but "hard" is also "brittle." Bad thing.)
I did a FA report on one for Manufacturing Materials & Processes in school a few years back, since I was replacing the damned thing and ripping it down for scrap anyhow. I learned a lot...
