Axles and Gears? - JeepForum.com
post #1 of 3 Old 10-29-2001, 06:16 PM Thread Starter
Marshmellow
Axles and Gears?
Bought a '92 and had some fun this summer in Colorado, but see the need for some improvements....
Have'nt decided on which lockers and gears to go to, but need some help determining what I have already....Maybe the numbers will tell the story....Here they are,..Need interpreter
Front Diff Cover (side between cover bolts) 52068203
4 10 610393 4
Front Axle - 1 15 97 8C 610393 4
Rear Diff Cover - (Center of Cover)
Dana
43225
308 1
Rev E
031691
Rear Diff Cover (side between cover bolts)
52068010
4 11 5502 4
Transfer case Tag - NP231 J
5300 8211
17 92 2
272 ratio
I'm assuming the 4 11 and 4 10 indicates the gears, but should'nt they be the same?
Just beginning to learn....Need some feed back
Marshmellow is offline
post #2 of 3 Old 10-29-2001, 06:19 PM
osburn
osburn's Avatar
That's normal for the front to be 1 to 2 higher (numerically lower). What you can do is take your VIN down to a dealer and ask them to run a Function 69 (yeah I know, makes the number really easy to remember though) on it. That will give you a printout of your Jeep as it was produced in the factory. You'll know everything about it then.
Matt Osburn
Score 1032
osburn is offline
post #3 of 3 Old 10-29-2001, 09:14 PM
powjunkie
I just put those gears in my Jeep. You have 4.10's, unless the previous owner changed them. Osborn's right, the front is supposed to be a little different than the rear.
94 YJ 4", SYE, 33 mud t's on MT classics; 4.10's with Detroit Truetrac in rear
powjunkie is offline
Can I run different gears in my axles? treefiddyYJ YJ Wrangler Technical Forum 2 06-01-2009 08:36 AM
Gears and axles! Davidsv04 TJ Wrangler Technical Forum 15 01-07-2009 03:34 PM
what axles do i have and gears vermontjeep TJ Wrangler Technical Forum 2 03-19-2005 06:46 PM
New Gears...New Axles? roadking TJ Wrangler Technical Forum 11 08-07-2003 01:58 PM
What axles and gears do I have??? JKJoe TJ Wrangler Technical Forum 8 07-09-2002 04:35 PM
