Axles? - JeepForum.com
post #1 of 6 Old 03-04-2002, 09:42 PM Thread Starter
BzJeep
BzJeep's Avatar
Axles?
Where can I learn about this Dana 44 stuff? I have know clue what this stuff is. Can ya point me to a good spot?
2008 Metropolitan Gray Mazda3S Sport
2001 Steel Blue Grand Limited *SOLD*
1993 Forest Green Wrangler *SOLD*
Green Jeep Club Member #16
BzJeep is offline
post #2 of 6 Old 03-04-2002, 09:46 PM
RodeoRob
RodeoRob's Avatar
best bet is to use the search feature and read, read, read!!!
Also, there is no better place to learn about axle tech than the boards over at POR. (but be weary before you post, these guys don't take kindly to newbie )
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #3 of 6 Old 03-04-2002, 10:24 PM Thread Starter
BzJeep
BzJeep's Avatar
Well, I've changed my mind over to 33" BFG's but I don't know if I should still get a 4" SkyJacker lift, 3"BodyLift and TJ flares? Will it look to high for 33"ers?
Thanks..
PS: I didn't wanna do all this axle and gear stuff.
BzJeep is offline
post #4 of 6 Old 03-05-2002, 06:36 AM
RodeoRob
RodeoRob's Avatar
My friend runs a 4" RE lift w/ 2" of body and it looks just about right for 33x12.50's.
And with 33s, you shouldn't have to worry too much about changing axles providing you don't have a heavy foot. You could always look at a Ford 8.8 rear axle swap, pretty brainless swap and it would get rid of that horrible D35c.
-Rob
Robert Gorrell
RodeoRob is offline
post #5 of 6 Old 03-05-2002, 01:43 PM Thread Starter
BzJeep
BzJeep's Avatar
How much will a Dana 44 axle cost? If Im going to get a new axle would I need a new front AND rear axle? Or just a rear?
PS: If I get a new axle, I would go back to 35" tires because its just more worth it.
Thanks!
BzJeep is offline
post #6 of 6 Old 03-05-2002, 02:29 PM
SBall
Go for the 4" Skyjacker, a 1-2" body, the TJ flares and 35" tires. Then get the Super 35 kit which makes the Dana 35 rear quite strong, plus you get a locker. If you want to upgrade the front axle, get the axles out of a TJ Dana 30 front(not the axle housing, but the actual inner axles), they are stronger than the YJ's and will fit inside your Dana 30 housing. And as long as you are at it, get some gears. Of course this is only one out of many options. As mentioned, the Ford 8.8 is a popular swap. Or a Dana 60 and 44 out of a late 70's Ford, or call Currie or Dynatrac and order a couple. This is one of those topics that can be discussed for a long time. The major issue is money and what you plan to do with your jeep. It is always a good idea to plan ahead for the future of your jeep so you dont waste time and money setting it up one way and then changing your mind.
92 YJ 4.0L, 35" Goodyear MTR's, Rough Country Suspension
SBall is offline
Dodge axles VS Ford Axles???? Allen52105 YJ Wrangler Technical Forum 7 08-07-2009 01:23 PM
Swapped axles- No ABS on new axles????? suprman4real YJ Wrangler Technical Forum 2 05-11-2009 07:52 PM
94 axles to 91 Axles Brake issue???? lawson1273 YJ Wrangler Technical Forum 1 12-13-2008 10:10 AM
New JK Axles/Mopar Performance Axles Badcbr TJ Wrangler Technical Forum 8 08-21-2007 04:36 PM
Superior axles vs. Alloy axles BusyDoinNothing TJ Wrangler Technical Forum 21 06-30-2007 12:40 AM
