Axle wrap, something I thought the 2.5 couldnt do - Page 2 - JeepForum.com
post #16 of 22 Old 06-02-2010, 06:48 AM
TSEJEEPERS
Originally Posted by JeeperDon View Post
Agreed a bunch. It's all in the springs chosen. Stock YJ 2.5L springs, like those in the OPs photo appear to be, have near zero ability to deal with wrap. Other springs, like my 1.5" RubiExp SOA design springs have shown no bends at all after a few years of V6 power, 35's, and no AW-bar.
I ran RE SOA springs and still had axle wrap.
The springs themselves held up fine but I could not keep a rear driveshaft in it to save my life.
A traction bar took care of it.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #17 of 22 Old 06-02-2010, 08:53 AM
E_ROCK
Originally Posted by fratis View Post
not really. this is internet paranoia. without an anti-wrap i have bent spring packs but never broke any. the ones i have now (pre anti-wrap) are bent as well but still function fine. and as we all know the track bars have nothing to do with wrap.
those extra long perches are worthless.
I agree also. I put in an anti-wrap to prevent breaking U-joints, not to save springs.
Most trucks, all XJ, 80ish 4runners all come from the factory as SOA and no anti-wrap bar. They don't have u-joint problems because their drive train is longer which reduces the angle on u-joints.
Garage Monkey, Wheeling Junkie
E_ROCK is offline
post #18 of 22 Old 06-02-2010, 09:33 AM Thread Starter
YJames90
YJames90's Avatar
Those are 4WD hardware ( Procomp ) 2" lift springs
My 2.5 to 4.3 swap thread
YJames90 is offline
post #19 of 22 Old 06-02-2010, 09:41 AM
wrangler76
Low gears are just as big of a factor as a higher torque/hp motor.... Compare the end torque generated from a 4.0 180BHP/stock 3.07 gears to a 2.5 117BHP/aftermarket 4.88 gears.... When you're not moving forward you have 3 options: 1) Motor stalls, 2) Tires slip, 3) Something bends/brakes.
wrangler76 is offline
post #20 of 22 Old 06-02-2010, 09:49 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Holy crap James. I didn't realize it was your truck. Well the good news is you've had it apart so much so recently it should be an easy swap to new springs.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #21 of 22 Old 06-02-2010, 03:33 PM Thread Starter
YJames90
YJames90's Avatar
I am ordering the RE SOA springs tonight or tomorrow. The springs I have on now are a 2 inch lift and the RE springs are 1.5. I think I am safe enough that the front springs have sagged a half an inch so the new 1.5 inch rear springs should even things out.
Theres a great deal for JF members on those springs if you know where to look
YJames90 is offline
post #22 of 22 Old 06-02-2010, 04:35 PM
JeeperDon
JeeperDon's Avatar
I have the 5 leaf packs in front and the 6 leaf in back. They sit at the same height, but the rears are just a bit harsher ride. I figured the 6 leaf packs would help with wrap, and it's been a few years with SOA now and no bar and no wrap damage.
Here at our Rausch trip, the right front is stuffed to the bump stop, and the right rear is at the bottom of the droop allowed by the shocks.
Web Admin for
Axle Wrap?!?! Mr_E YJ Wrangler Technical Forum 21 08-11-2009 06:54 PM
help me put an end to axle wrap! (front axle) it's killing my jeep! Big-n-Broke-YJ YJ Wrangler Technical Forum 34 10-24-2007 07:40 PM
need some help (axle wrap) Yeepin YJ Wrangler Technical Forum 11 08-28-2007 07:14 AM
Axle Wrap? ckiel24 YJ Wrangler Technical Forum 5 03-15-2007 10:29 AM
Axle Wrap Claw TJ Wrangler Technical Forum 1 01-13-2004 08:18 AM
