Which Axle Will Let Go First? - JeepForum.com
post #1 of 3 Old 11-14-2001, 07:33 PM Thread Starter
CR Perry
Which axle will let go first on my YJ? The 30 in the front or the 35 in the rear? I'm running 33" tires with a Rubicon Express 4.5" lift. I like to tackle challenging trails in rocky, muddy Northeast conditions. Custom axles cost a grip. Any advice on swapping in heavy duty axles that are close to the right size?
95 Wrangler
Rubicon Express 4.5" Lift
CR Perry is offline
post #2 of 3 Old 11-14-2001, 09:01 PM
osburn
osburn's Avatar
You never know which axle is gonna go. That's why it's probably worth your while to just pick up the old axles from someone who is upgrading. I've always gotten my spares for free. But I hang around with a lot of Jeepers and upgrades happen a lot. Don't pay anyone a whole lot for their old axles. You are probably gonna gut them for the shafts, yokes, etc and toss the housing in a dumpster. By picking up whole axles you get all the stuff. The shafts, the yokes, hubs, etc for much less than buying just pieces. Also, you get the experience of tearing the axles down on the pavement while your Jeep is still functioning to run for the tools ya didn't know ya needed. Then when ya hit the dirt, who cares what happens. You're prepared.
Matt Osburn
Score 1032
osburn is offline
post #3 of 3 Old 11-14-2001, 09:08 PM
YJOHN
FROM MY EXPERIANCE OFF ROADING MOST GUYS BLOW UP THE FRONT AXEL BECAUSE WHEN THEY ARE IN THE MUD THEY SPIN THE TIRES TO CLEAR THE MUD OFF BUT WHEN THEY COME OUT OF THE HOLE THEY LET OFF TO LATE AND THE TIRES HIT DRY DIRT OR ROCK SPINING LIKE THERE IS NO TOMMOROW AND SNAP THERE GOES THE FRONT .WHILE THE REAR IS STILL HAPPY SPINNING IN THE MUD.
YJOHN is offline
Superior Axle's new axle Super Truss kit installed, beef up your axle for only $399 Jerry Bransford TJ Wrangler Technical Forum 164 01-09-2015 11:14 AM
Should the Front Axle & Rear Axle be off centered to the passanger side by .5"? Lemmiwinks TJ Wrangler Technical Forum 3 07-07-2009 09:27 AM
Superior Axle & Gear EVOLUTION SERIES Front Axle Tube Seals 95wrangler4life YJ Wrangler Technical Forum 3 02-17-2009 02:00 PM
What is the difference/benefit of a high pinion axle compared to a regular axle? bhicks TJ Wrangler Technical Forum 7 09-10-2008 03:32 PM
