Axle upgrade poll - Page 2 - JeepForum.com
View Poll Results: which 8.8 upgrade
Superior Axle and Gear super 88 kit 27 90.00%
chromoly shafts with C clip still in it 3 10.00%
Voters: 30. You may not vote on this poll
post #16 of 21 Old 04-11-2010, 06:52 PM
Larry93
Originally Posted by jeepster93 View Post
Be sure you have a good quality bearing puller. The 8.8 axle bearings do not come out easy.
Mine came out with a slide hammer, although I do recall one side giving one hell of a fight.
Larry93 is offline
post #17 of 21 Old 04-11-2010, 10:33 PM Thread Starter
Jedidiah
1995 XJ Cherokee
Originally Posted by roccomonte View Post
Have you broken the 8.8? If you still have that d30 up front I'd worry about that before the 8.8 upgrades.
My friend runs an ford 8.8 in his toyota with the v6 supercharged on 35's and he drives it hard, and its held up real good.
Well, this check is the super 88 and my next one will be the chromoly D30 shafts with the disconnect eliminator.
Jedidiah is offline
post #18 of 21 Old 04-11-2010, 11:17 PM
roccomonte
I dunno, I guess I'm more of the if it ain't broke don't fix it type guy. I'd sit at my desk thinking if I never upgraded that, would it have broken?
roccomonte is offline
post #19 of 21 Old 04-12-2010, 12:29 AM Thread Starter
Jedidiah
1995 XJ Cherokee
Well, if that is really your thinking then why isn't your Jeep stock?
Jedidiah is offline
post #20 of 21 Old 04-12-2010, 01:15 AM
roccomonte
I've not replaced one part I haven't broken duh With the exception of my shackles and my cage, I will be replacing parts to make it better one i start making some more money but untill then shes staying as is.
post #21 of 21 Old 04-12-2010, 09:26 AM
jeepster93
jeepster93's Avatar
On the new kits they should already come pressed on from what I've read.
NOT true.
My kit was a "new" kit. At least this is what both Northridge and Superior said when I called them and said "WTF". It was bought from Northridge and shipped from Superior(dropped shipped).
I got it several months ago. With the bearings NOT pressed on.
Just expect to do this yourself.
Also my c-clip eliminators are covered in rust.
jeepster93 is offline
Dana 35 axle Poll kingvm TJ Wrangler Technical Forum 151 09-10-2012 07:33 AM
Leaking Axle seal on the front. Should I upgrade the axle to a dana 44? MWguy101 YJ Wrangler Technical Forum 21 03-01-2012 12:08 PM
Dana 35 axle Poll kingvm YJ Wrangler Technical Forum 25 03-24-2011 01:03 PM
Poll: Best TJ axle swap danielgoforth TJ Wrangler Technical Forum 66 05-17-2008 07:35 AM
Poll: REAR AXLE SWAPS Stormtrooper TJ Wrangler Technical Forum 14 11-01-2004 05:52 PM
