Axle upgrade poll - JeepForum.com
View Poll Results: which 8.8 upgrade
Superior Axle and Gear super 88 kit 27 90.00%
chromoly shafts with C clip still in it 3 10.00%
Voters: 30. You may not vote on this poll
post #1 of 21 Old 04-10-2010, 03:20 PM Thread Starter
Jedidiah
1995 XJ Cherokee
Axle upgrade poll
Looking to upgrade my 8.8
What do you guys think? Super 88 kit or just chromoly shafts?
Jedidiah is offline
post #2 of 21 Old 04-10-2010, 03:53 PM
provinT13
The chromoly shafts would be easier to swap in, but It would be nice to get rid of the c-clips, so the super 88 with c-clip eliminators get my vote. Honestly it's probably not really needed with an open diff on 35's. I'd spend that money towards a locker before an axle shaft upgrade, just my
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #3 of 21 Old 04-10-2010, 03:55 PM Thread Starter
Jedidiah
1995 XJ Cherokee
I have an ARB in my rear end.
Jedidiah is offline
post #4 of 21 Old 04-10-2010, 04:27 PM
provinT13
Strange, I must not have seen that when I looked at your profile. Well my first post still stands, the super 88 gets my vote. Locked on 35's would still be pretty tuff to break an 8.8 shaft, but if everything else is in check, might as well beef it up
post #5 of 21 Old 04-10-2010, 06:05 PM
timatoe
timatoe's Avatar
How much are just the chromo shafts? I didn't look real hard, but didn't find a price right away. For $562 for the Super 8.8 set up, I plan to eventually go that route.
timatoe is offline
post #6 of 21 Old 04-10-2010, 06:55 PM Thread Starter
Jedidiah
1995 XJ Cherokee
I think you're looking at around 170-190 per shaft for just the chromolys
Jedidiah is offline
post #7 of 21 Old 04-10-2010, 09:06 PM
timatoe
timatoe's Avatar
Yeah, so then I'd definitely go Super88
timatoe is offline
post #8 of 21 Old 04-10-2010, 09:07 PM
JohndKc
1987 YJ Wrangler
If you buy a super88 kit, buy it from superior directly on the weekends. They usually are 10% off on the weekends.
33rd BCT
Alpha 2/122 FA
68W
JohndKc is offline
post #9 of 21 Old 04-10-2010, 09:55 PM Thread Starter
Jedidiah
1995 XJ Cherokee
Originally Posted by JohndKc View Post
If you buy a super88 kit, buy it from superior directly on the weekends. They usually are 10% on the weekends.
Thanks for the tip.
Jedidiah is offline
post #10 of 21 Old 04-10-2010, 11:40 PM
Larry93
I did the 8.8 superior gear conversion. It went well, although when you cut the axle tubes make for dam sure you mill file the surface perfectly flat. A good 30 minute per side hand filing is what it took me to get a good surface. The older kits will come without the bearings pressed on and from what I have heard the newer kits already have them pressed on. I overloaded a 10 ton press trying to drive my bearings and retainers on. Eventually sandwiched a 20 ton bottle jack in between the 10 ton press to finish the job. Best part about the kit is if you decide to swap to a dana 44 later on in the front you can change your bolt pattern in the rear to match.
I purchased from here, cheapest I have come across on the internet:
Superior Axle Super 88 Axle System for Ford 8.8 Inch
When I did the install I also added a detroit true-trac at the same time. By far the last thing that will ever die on my Jeep now.
Larry93 is offline
post #11 of 21 Old 04-11-2010, 01:43 AM
Allen52105
NO CONTEST super 8.8
jason
Allen52105 is offline
post #12 of 21 Old 04-11-2010, 07:49 AM
jeepster93
jeepster93's Avatar
When it was MY money...
I did a Super 88. Got it from Northridge(free shipping).
Be sure you have a good quality bearing puller. The 8.8 axle bearings do not come out easy.
I had to have a shop press on the 88 bearings too.
jeepster93 is online now
post #13 of 21 Old 04-11-2010, 08:51 AM Thread Starter
Jedidiah
1995 XJ Cherokee
On the new kits they should already come pressed on from what I've read.
Jedidiah is offline
post #14 of 21 Old 04-11-2010, 09:25 AM
roccomonte
Have you broken the 8.8? If you still have that d30 up front I'd worry about that before the 8.8 upgrades.
My friend runs an ford 8.8 in his toyota with the v6 supercharged on 35's and he drives it hard, and its held up real good.
roccomonte is offline
post #15 of 21 Old 04-11-2010, 05:49 PM
Larry93
Yes but how many old kits need to be sold to clear inventory for the new. When I bought mine, the new kit was well into market and I still got the old one.
Larry93 is offline
Dana 35 axle Poll kingvm TJ Wrangler Technical Forum 151 09-10-2012 06:33 AM
Leaking Axle seal on the front. Should I upgrade the axle to a dana 44? MWguy101 YJ Wrangler Technical Forum 21 03-01-2012 11:08 AM
Dana 35 axle Poll kingvm YJ Wrangler Technical Forum 25 03-24-2011 12:03 PM
Poll: Best TJ axle swap danielgoforth TJ Wrangler Technical Forum 66 05-17-2008 06:35 AM
Poll: REAR AXLE SWAPS Stormtrooper TJ Wrangler Technical Forum 14 11-01-2004 04:52 PM
