#1 | |
axle upgrade ?
i have a 91 yj with a 4.0 manual tranny. im looking to upgrade my axles but i would like to see what everyones opinion is on the subject. i plan on running either 35s if i dont go all out, or 38s or 39s if i go all the way. ive read a lot on the 8.8s dana 44s and 60s. also to throw into the mix, im trying to keep from cutting down the axle housing. i have a lot of knowledge in mechanics but dont have the money to send them out to be sized to the jeep. which also says that i would like to keep it to something that is almost ready to bolt in without moving much. my intent is to have a respectable daily driver with the offroad performance to mud and rockclimb. well i think that about covers most of my question. cant wait to hear your responses.
#2 |
Part of the Three Percent
This guy just did a bolt in 8.8 in his TJ. I'm sure they can do them for a YJ aswell.
http://jeepforum.com/forum/showthread.php?t=365948&highlight=ford+axle |
#3 |
One thing to consider:
Look ahead and decide where you are going with this thing before you invest. I have the 8.8 right now and love it, but It has seriously narrowed my front axle upgrade options. I am stuck with trying to find a Waggy front d-44 (no easy task around here) or going chromo shafts in the D-30 (but It's still D-30 axle tubes). Anything other than that would require redrilling the rear axle bolt pattern and getting new rims. |
#4 |
I have a waggy D44 and mine is 6 on 5.5 and the 8.8 is 5x4.5 unless you can change the D44 easily.
1993 Jeep Wrangler 4.0L Tom Woods rear HD shaft D30 w/yukon alloys, lock right, jb4x4 bracket, Rusty's HD tie rod 8.8w/ LSD,5" BDS, homemade greasable boomerang shackles, SS braided lines, rubicon flares, 1" prothane body lift, 35" TrXus M/T, smitty built XRC, armor and a paint job soon to come. |
#5 | |
#6 |
IF you go with an 8.8 and upgrade teh axle shafts, you can get them in any bolt pattern you want for a couple bucks more. I have Yukon 8.8 shafts on my shelf that are drilled for both, 5x4.5 and 5x5.5.
not reall y abig problem if your going to upgrading things any way. |
#7 |
yeah the only g-wag axles I've seen are the 6x5.5" bolt pattern so you need either a toyota 8" LP rear end (the HP break all the time very easily) or a rear 44 out of a waggy. Those are my two options I've been looking at recently. Trying to build my first set of axles. but anyway that's my .02
#8 |
You can get wheel spacers/addapters for 5 on 4.5 to 5 on 5.5" lug patterns. that might be a idea for you.
'91 YJ. 4.0 TF999, D300 w/ 4:1, twin sticks. Chevy D44 front, 4.10's, spooled, Yukon 4340 shafts w/ super joints. Warn premium lock outs, High steer, ram assist. Dodge D60HD rear, 4.10's, welded, disc brakes. SOA front w/ RE 1.5" SOA leaf packs. Custom 4 link rear w/16" fox air shocks, stretched to 110". 38x12.5x15 TSLs on crager Nomads w/ DIY beadlocks. Tolly Fab Tube fenders, rocker gaurds, cage. 15gal stainless steel fuel tank. |
#9 |
The 8.8 has a rediculously strong housing, which makes it good for upgrading. Drag race guys will throw well over 1000 hp into them. I had never heard it before, but if you do a search, I saw someone talking about a shop they knew of that even made 35 spline axle shafts for these and could somehow get arbs anddetroits for them. Just make sure you weld the housing to the pumpkin. Other than that, I paid $300 for mine out of a 97 explorer with 60,000 miles, disk brakes, and 4.10 gears...I love it, probally one of the best mods I have ever done.
1992 Wrangler Sahara, 4.0L, 5spd, RE 4.5 XD lift, Fox remote reservoir shox, 33x12.5-15 BFGoodrich All-Terrains, 15x8 black rock crawlers, JK rubicon pneumatic swaybar, JKS quick disconnect track bar, Teraflex HD SYE, Tom Woods driveshaft, Ford 8.8 w/ 4.10 gears and arb locker, D30 w/ 4.11 gears and arb locker, York 210R OBA w/ Kilby mount, Dynomax Ultra Flow SS muffler, Alterstart 165A alternator, TJ flares, and Poison Spyder rocker knockers. |
#10 |
You could always go with a 9" in the front..
Zane Neher 88 YJ. H.O. 4.0L/AW4/twin sticked d300/1 tons/38.5s. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
