"Axle Under Lift"? - JeepForum.com
post #1 of 12 Old 09-18-2005, 08:03 PM Thread Starter
SwearingYeti
SwearingYeti's Avatar
"Axle Under Lift"?
While talking to my neighbor recently (He owns a '97 TJ), he said something to me about getting something called an axle under lift. He said it had something to do with the axle going under the leaf spring, and its about a 5" inch lift. I have never heard of it and he didnt know a whole lot... so can anyone tell me more about it?
Thanks
1991 Red YJ - 2.5L
1988 Red YJ -304ci
1989 OD XJ- 4.0L
SwearingYeti is offline
post #2 of 12 Old 09-18-2005, 08:10 PM
dylanking
Sounds to me like a SOA or Spring Over Axle lift. You get a lot of height from it for a reasonable price, it's also easier to replace factory springs when you start to sag than it is to deal with a sagging suspension lift.
dylanking is offline
post #3 of 12 Old 09-18-2005, 08:10 PM
jeepmud
its called a soa (spring over axel conversion) and you pretty much get the height of the axel tube as that much more lift with out sacrificing how it drives
I still dont see y the motor mount broke.....it was only 6 feet of air.
94 yj 2.5L-Custom Snorkel, Custom Interior(Spray Paint), 30's in the back, 205's in the front, 9 piece windshield,
jeepmud is offline
post #4 of 12 Old 09-18-2005, 08:28 PM
TellyDSP
Poland and PPV!!!!
Thanks
it's not so simple. It's a SOA(spring over axle) as mentioned above. It should net you bout 5.5". When going that high along with the SOA setup, you will have to consider the cost of an SYE/CV combo for driveline angles, brake lines, possibly steering issues, axle wrap, and tires and their affect on power and you stock axles.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #5 of 12 Old 09-19-2005, 04:53 AM
ginsy
going SOA is no walk in the park. it generally requires new axels, some steering components, like a high steer system, dont think you need it with stock springs though. extended brake lines, drive line angles. wether or not its your daily driver makes a difference too
RED JEEP CLUB # 295
1990 yj
4.2L-5spd
3.5"black diamond lift
1.5"shackle lift
33" kumho venture m/t
ginsy is offline
post #6 of 12 Old 09-19-2005, 07:45 PM Thread Starter
SwearingYeti
so do you or do you not reccomend it it?
1991 Red YJ - 2.5L
1988 Red YJ -304ci
1989 OD XJ- 4.0L
post #7 of 12 Old 09-19-2005, 08:43 PM
xeon
You can definitally do it. Its just very costly and hard to get right if you DD. I am doing it very soon and its going to be my DD with 2" spring too. Its going to have like 7-8" of lift along with 35's or 37's. And Vortec motor... blah blah lots of money. Anyway you have to deal with steering, rear axle (the Dana 30 front will hold up to 37s, that I have seen), CV shafts front and rear, SYE, shocks, mounts brake lines and some other misc stuff . Hope this helps out.
88YJ, 350TBI, 700R4, Atlas 4.3, HP60, 14B (At a mall near you)
Tri-State (NJ-NY-PA) 4x4 Wheeling Group
xeon is offline
post #8 of 12 Old 09-20-2005, 09:17 AM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
It is not as hard as every one is making it out to be. My buddy Charlie did his in one day, but he has access to a shop, welder and big bench vice. He already had a RE XD 4.5 in SUA lift so he had the needed stering parts and brakelines. He used an old saggy set of stock wrangler springs (from the JY) and then cut the spring eyes off of some rear ford ranger mainsprings (also saggy, and negative arched) and placed it on top of the wrangler spring pack to help control spring wrap. It works nicely. He also cut off the old perches and re-used them, make sure you get the proper angle when you reatatch them. You will want to lots of research BEFORE you start this. But the average person with a welder and some tools will be able to do this in a weekend just like any other lift. IIRC he was into his @ $130, but like I said, he already had everything but the junk yard springs, ubolts and the ranger mains I gave to him.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #9 of 12 Old 09-20-2005, 12:04 PM
E_ROCK
This is what you are in for:
http://www.jeepforum.com/forum/f37/waggy-d44-axle-swap-yj-189711/
I did an axle swap at the same time as a SOA, but the process is the basically the same.
Garage Monkey, Wheeling Junkie
E_ROCK is offline
post #10 of 12 Old 09-20-2005, 12:54 PM
A1C Toves
i would go with a standard suspension lift, and when you come across the beefy things like axles and motors, then go for it. but any how, its your option..if you have time and money, go for it.
A1C Toves is offline
post #11 of 12 Old 09-20-2005, 01:13 PM
BackRoadJPin
1995 Wrangler
BackRoadJPin's Avatar
depends on the type of wheeling you will be doing, if you are just going to hit the trails every so often, then SUA lifts are your thing.
But if you are going after serious flex, softer ride, and will off road this often and looking to run 35+ inche tires then save your money find the right axles, and start buying the needed items and go SOA.
I have researched this to death and I have come to the conclusion that SOA will cost me only a bit more than the 4-5 inche SUA lifts that I was looking at.
4-5 inch SUA I was still going to have to install SYE / CV rear and then run the risk of an even stiffer ride on road, and potential lose of flex out on the trail.
I have an axle swap for the rear planned all ready so it only makes sense to go for it.
RE sells a complete SOA kit includes the extended brake lines, I will use my existing 2" springs may end up removing a leaf or two to stay around the 5-6 inch lift range.
I purchase my jeep with the lift all ready installed, but looking into this and what the SUA kits cost it just did not make sense to me to spend the money only to find out that I may want/need more lift anyways so I will wait it out and make my move when all the parts are collected.
Just my take based on the research that I have done on this site and others, there are so many posts on this topic that you start to see all that has been done and that some are content with their SUA, but most wish they had done SOA.
Back Road Jeepin
BackRoadJPin is offline
post #12 of 12 Old 09-20-2005, 05:13 PM Thread Starter
SwearingYeti
Alrighty, so i cant keep everything stock, and use it as a cheap lift, as i was planning. Its a beater Jeep until I start working full time, I'm not looking to spend an arm and a leg, i just want a cheap lift to beat off roading, I'm also planning on 33's
So if this is not a "cheap lift", what is besides a body lift?
Orrr, is there such thing as a "cheap lift"?
1991 Red YJ - 2.5L
1988 Red YJ -304ci
1989 OD XJ- 4.0L
Running 37s on a 2.5" or 3" lift, 1" body lift, and flat flares planman JK Wrangler Technical Forum 44 01-31-2016 09:44 PM
Please noob-proof this setup -2" BB, 1" Body Lift, 1"Motor Lift jondotcom TJ Wrangler Technical Forum 10 03-06-2010 02:43 PM
"project Cheap Jeep" - 5-6" Lift - Looking For Oem Shocks For "xx" Lift Jeepwood YJ Wrangler Technical Forum 4 11-26-2009 07:32 PM
OME 2" lift and 1.25" body lift. Gives good ride - adequate clearance for 33" tires? CB3 TJ Wrangler Technical Forum 30 11-25-2009 12:13 AM
