Axle swaps? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Axle swaps?
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 02-08-2013, 10:50 PM   #1
gfd66
Axle swaps?
Started talking to a couple of jeep guys up here and they mentioned to me that I might want to look into "full width" axles but then did not elaborate. Any ideas what they were talking about? Also, while I'm in the subject, what gears do you guys think I should be running with 35's? The jeep becomes a dog in 5th gear and I think that the diffs are stock.
Genius might be the ability to say a profound thing in a simple way.
Charles Bukowski
gfd66 is offline   Reply With Quote Quick reply to this message
Unread 02-08-2013, 10:56 PM   #2
linusb
I believe those would be axles from a full sized truck. Dana 60s, etc.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline   Reply With Quote Quick reply to this message
Unread 02-08-2013, 11:02 PM   #3
czjeeper
Full width isn't "street legal" and doesn't fit most trail where I'm at.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out! Piston's Wild Motorsports Club
Click here for 2.5L AX5 to AX15 swap
czjeeper is offline   Reply With Quote Quick reply to this message
Unread 02-08-2013, 11:13 PM   #4
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
Search for the infinite explorer 8.8 swap threads out there.
Mail crawling.
MisfitSeven is offline   Reply With Quote Quick reply to this message
Unread 02-09-2013, 12:08 AM   #5
Noltz
YJ Wrangler
Your profile says you're in a 4.2, so you've likely got 3.53 or 3.07 gearing now. You want to find a front axle from a 4 cylinder YJ. They're equipped with 4.10 ratio from the factory, and will bolt in. Then you want to find a rear Explorer axle like Misfit says. They're also available in 4.10 ratio from the factory. They're almost a bolt in. Do a search for "YJ 8.8 swap"... it's been done 100's of times. There's one in the back of mine, and a bonus upgrade to rear disc brakes.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4½" & shackles, BFG 33's (sold)
Noltz is offline   Reply With Quote Quick reply to this message
Unread 02-09-2013, 07:46 AM   #6
linusb
Concur with others. 8.8 here. Fun swap. Find a friend who can weld on some new perches and you'll be good to go.
Unread 02-09-2013, 08:16 AM   #7
modfox
Yes 8.8 here also.
You can have it done in a day with someone that can weld. Very nice upgrade!
90 YJ 4 cyl 5 speed
65 Ford Mustang 289/c4
2010 Kia Soul
modfox is offline   Reply With Quote Quick reply to this message
Unread 02-11-2013, 10:07 PM   #8
gfd66
OK, Thanks for all of the info. I've got feelers out for the axles recommended. Not a lot of good boneyards around me though. I've got a good hour + in any direction to try to find Jeep or "can be used on a Jeep" parts. Are there particular markings on the axles that are running 4:10 gears?
Charles Bukowski
Unread 02-11-2013, 10:09 PM   #9
JeepinJeremy
ratio tags on the diff cover if still attached or pull the cover and count the teeth on ring and pinion. Look at stamp on ring gear
JeepinJeremy is offline   Reply With Quote Quick reply to this message
