axle swap question -
post #1 of 2 Old 07-19-2001, 12:40 AM Thread Starter
axle swap question
Is an 87 wranglers' axle compatible with a 95yj? (both are dana 35's) It's going to have 4.56 gears. Whereas I have 3.07. Would it be a straight swap or require modifications? What is the typical cost to expect for a gear swap in a front Dana 30?
Thanks In-Advance
95, 4.0, 4" sky jacker lift, warn 9500i, tomken rear w/ swing out, 33x12.5 pro comp mud's, 3" body lift, sway disconnects, NO track bars & custom front bumper
winokko is offline
post #2 of 2 Old 07-19-2001, 12:43 PM
rayray's Avatar
It should be a straight swap. However, unless your getting a great deal, I would look for a d44 or better. The only benefit you'll gain with the 87 axle is the non c-clip axle shafts. Keep that in mind when/if your looking for a locker.
The gear swap should run around 300 if you know someone who can do the work for a reasonable cost. That cost includes the gear's, complete install kit, and shipping/tax.
Earth First! We can wheel the other planets later
rayray is offline
In order to be able to post messages on the forums, you must first register.
j-10 axle swap question lobukjeep YJ Wrangler Technical Forum 2 01-03-2010 06:19 PM
axle swap question epeck87 TJ Wrangler Technical Forum 2 06-23-2009 12:31 PM
TJ Axle Swap Question kgnorman TJ Wrangler Technical Forum 1 01-11-2008 05:46 AM
TJ Axle Swap Question kgnorman YJ Wrangler Technical Forum 3 01-10-2008 12:03 PM
Axle swap question SafetyMan YJ Wrangler Technical Forum 1 06-06-2006 04:38 PM
