axle swap question - JeepForum.com
post #1 of 2 Old 09-04-2011, 03:26 PM Thread Starter
wanabejeeper
1987 YJ Wrangler
axle swap question
found out I have crappy 3.07 gears and with the 33's the PO put on it explains some things... Since I want to replace the gears I'm thinking i do an axle swap at the same time depending...
What is the closest axle swap using junkyard supplies that would be a near bolt in replacement... little or no welding.
I'm not going to do real serious wheeling mostly sand trails and mud/water around here in south Jersey. little or no rock crawling.
87 YJ The Original!
It goes in that barrel you wheel out to the street once a week.
My build thread
wanabejeeper is offline
post #2 of 2 Old 09-04-2011, 03:55 PM
notmyj
Ford 8.8 from an explorer. Find one with 4.10's then get a complete front axle from a 4 cylinder yj. The 8.8 is the easiest swap, with just a small amount of welding. (Spring perches and shock mounts). The front axle will bolt in. The 8.8 is almost the same width, the same bolt pattern and has rear disc brakes. Do a search for yj 8.8 swap on Google. You will find tons of info and how to pages.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
Axle Swap Question TheGilMan YJ Wrangler Technical Forum 9 10-12-2010 09:39 PM
j-10 axle swap question lobukjeep YJ Wrangler Technical Forum 2 01-03-2010 06:19 PM
Question about axle swap jeremy91yj YJ Wrangler Technical Forum 5 06-23-2009 07:55 PM
Axle swap question dadstoys2 YJ Wrangler Technical Forum 4 10-17-2006 11:26 PM
Axle Swap question DustinM YJ Wrangler Technical Forum 3 07-26-2006 02:00 PM
