Axle swap options - JeepForum.com
post #1 of 4 Old 04-24-2002, 11:10 AM Thread Starter
ohio yj
Axle swap options
There are so many options out there for axle swaps on jeeps. Is it that much cheaper to find one out of a junk yard, clean it up and rebuild it versus just buying a complete axle assembly (Currie)? Or is it just a hassle saving step to buy a built assembly. I am looking at swapping out the D35 for a 44 with an ARB and regearing the front.
ohio yj is offline
post #2 of 4 Old 04-24-2002, 11:25 AM
Bob J
Bob J's Avatar
1984
The best way to go would be to get a D44 front end from an early 80's Wagoneer. All you have to do is move the spring pearches in 1/2" each and figure out what to do about the bolt pattern. You can try and switch the front which could be alot of trouble, or get custom axle shafts for the rear to match.
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline
post #3 of 4 Old 04-24-2002, 11:44 AM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
87 to 91 Grand Wagoneer's had D/44's front & rear and are the easiest swap into a Wrangler. The earlier Waggy's (81 - 86?) had an AMC20 rear with factory one-piece axles and thicker axles tubes making this assembly MUCH stronger than a D/44. The only downside on all Waggy diffs is the bolt pattern is 6 lug.
Steve
OldJeepguy is offline
post #4 of 4 Old 04-24-2002, 12:11 PM Thread Starter
ohio yj
Thanks for the help you guys, now that bring me to another question. Changing the bolt pattern? Is there a conversion kit that can be purchased or is it a matter of buying new axle shafts and brakes that are five bolt?
ohio yj is offline
TJ axle swap options jaspepp TJ Wrangler Technical Forum 15 11-29-2015 08:43 AM
1988 3.07 rear axle swap options derrick2500 YJ Wrangler Technical Forum 2 10-10-2009 09:54 AM
Need Opinions on axle options and Axle appraisal Marine_Mike YJ Wrangler Technical Forum 5 06-18-2009 02:00 PM
Axle Swap Options JwlmanWu YJ Wrangler Technical Forum 0 01-25-2007 09:24 PM
Axle Swap Options MCanavan TJ Wrangler Technical Forum 16 04-11-2006 05:11 PM
