Axle Swap... Cutting Axle - Page 2 - JeepForum.com
post #16 of 21 Old 09-22-2010, 09:04 AM
Krochus
Originally Posted by DDT3 View Post
Also why cant I attach a pic on here. When I click insert image it asks my for a web address type thing. I just cant attach a image from my pics on my computer?
click upload images in the 'attach files" box in additional options below the reply box (not quick reply)
Think Green recycle your YJ's sway and trac bars today!
Originally Posted by buickgnx88 View Post
"Jeep Wave threads, it's a newb thing, you wouldn't understand!"
Krochus is offline
post #17 of 21 Old 09-22-2010, 09:25 AM Thread Starter
DDT3
Yeap thats how it is on the hunting forum I go to. I just read here you need to have 25 posts before you can add a pic... Not a good feature...
DDT3 is offline
post #18 of 21 Old 09-22-2010, 07:37 PM Thread Starter
DDT3
I bought the axles today!! I will post my build plan tomorrow. I know I will need some advise. Thanks
DDT3 is offline
post #19 of 21 Old 03-13-2014, 08:51 PM
ROCCRAWLER3
In regards to the subject of 37's and the 2.5l engine not being "peppy" enough I have to say that's not true! Several years ago Tri-County Gear built a Yellow Jeep Wrangler Rock Crawler in which they changed everything but the stock 4cyl motor and ran it and won many competitions and if I am correct they did so just to prove that the stock 4cyl was a strong reliable motor. they competed with 35in tires with no problems. http://www.fourwheeler.com/how-to/16...-rock-crawler/
ROCCRAWLER3 is offline
post #20 of 21 Old 03-14-2014, 12:14 AM
Norcal_chris
Norcal_chris's Avatar
Offroad it doesn't matter unless you are rock bouncing.
My 2.5 has zero issues in that regard. It's every other aspect of it. Try and blast hills with 37s and you feel the pain
Just realized the unnecessary necro thread too...... Wow
Ruined a perfectly good jeep.
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline
post #21 of 21 Old 03-14-2014, 02:17 AM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Originally Posted by fratis
if the rest of the j10 is ok id take the whole thing and wheel that.
This. A guy I worked with had one for $600. If I knew more about it/them I would've been all over it.
Originally Posted by Krochus
In the subject if 37"s on a 2.5L. They don't make a gear low enough that'll make the 4 popper adequate by any stretch of the imagination.
Better tell ZTE that. Hahaha
Michaelgoesrawr is offline
Rubi swap / Axle swap (merged) tjmike TJ Wrangler Technical Forum 5 06-10-2010 01:04 PM
d30 yj to tj axle shaft or full axle swap? Rocky_Cosmark YJ Wrangler Technical Forum 3 02-14-2010 10:48 AM
Gathering parts for Axle swap, SOA, and V8 swap... tank29 YJ Wrangler Technical Forum 7 12-03-2009 02:42 AM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 03:28 PM
Cutting old axle brackets...need advice! jackal TJ Wrangler Technical Forum 3 04-04-2005 10:49 PM
