Axle Swap... Cutting Axle - JeepForum.com
post #1 of 21 Old 09-21-2010, 07:54 PM Thread Starter
DDT3
I have a 93 yj. Today I found a 1982 J 10 truck. It has a AMC 20 rear and D44 front. I have been told the axle length's on the J 10's are 65 inches wide and my yj's are 59ish. I am going to do a SOA so I will be moving perches and shock mounts. SO do I need to shorten the new axles or can I leave them at 65 inches? I need to know asap cause these axles wont last long. Thanks.
DDT3 is offline
post #2 of 21 Old 09-21-2010, 08:02 PM
93jeepyj
It wouldn't be worth the effort to cut them down. You can run wheels with more back spacing to make up for some of the extra width.
93jeepyj is offline
post #3 of 21 Old 09-21-2010, 08:24 PM
Krochus
You don't want anything to do with an AMC20
Think Green recycle your YJ's sway and trac bars today!
Originally Posted by buickgnx88 View Post
"Jeep Wave threads, it's a newb thing, you wouldn't understand!"
Krochus is offline
post #4 of 21 Old 09-21-2010, 08:26 PM Thread Starter
DDT3
Why is that?
DDT3 is offline
post #5 of 21 Old 09-21-2010, 08:28 PM
ImpactFabWorks
the AMC 20 just isn't worth the work you'll have to put into it. what is your build plan?
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #6 of 21 Old 09-21-2010, 08:30 PM
Rattyflatty
1948 CJ2A
If you don't mind axles that wide the easiest ones to swap when doing a SOA are the Dana 44 front/Ford 9" rear from a 78-79 Ford Extended Cab 1/2 ton. Those had SO leafs on front and I think the spring pad width is only 1/2" wider.
The 3/4 tons are easier to find(they all had leafs) if you are ok with 8 lug rims.
Rattyflatty is offline
post #7 of 21 Old 09-21-2010, 08:31 PM
Krochus
Originally Posted by DDT3 View Post
Why is that?
Because if there ever was an axle that's a downgrade (for various reasons) from a d35 it's an amc 20
Krochus is offline
post #8 of 21 Old 09-21-2010, 08:43 PM Thread Starter
DDT3
i only have the 2.5L. I would like to run the 35x10.5 bogger or the 37x13 bogger and gear the axles correctly and go. This is not my daily driver at all. It will only be used in the mud and to drive down the street and fill up with gas. So what does everyone think my best option is? I really dont want to spend alot of money.
DDT3 is offline
post #9 of 21 Old 09-21-2010, 10:00 PM
jbolty
jbolty's Avatar
as normal the best option is generally an 8.8. The width is about right, it's strong, they are cheap, easy to come by and come in several different gear set ups.
amc 20 has no aftermarket support and if you make a mongrel by shortinging it you will be screwed if you ever need another shaft.
jbolty is offline
post #10 of 21 Old 09-21-2010, 10:45 PM
TSEJEEPERS
The AMC 20 in the J trucks are stronger than the ones used in the CJs.
They already have one peice axle shafts and the tubes are thicker.
Stength wise they are comparable to a 44.
If it was me I would leave the axles full width.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #11 of 21 Old 09-22-2010, 02:08 AM
fratis
fratis's Avatar
if the rest of the j10 is ok id take the whole thing and wheel that. theres enough of us yj on the trail. its getting boring.
cutting axles down was pretty common but is getting more rare. with such strong aftermarket support less and less people are doing junkyard rebuilds and just going straight to aftermarket assemblies that come in any width the customer wants. also people are getting used to seeing more aggressively built vehicles. there was a day when having dana 44s with a rear limited slip and 33 made you the top dog. those days are long gone.
id probably use them full width.
fratis is offline
post #12 of 21 Old 09-22-2010, 07:19 AM
Krochus
IMO in a yj Dana 44' are obsolete. You do an 8.8 swap and a shaft upgrade in the HP30. When you get to the point these axles aren't enough you go straight to 1 tons and skip the 44's.
I honestly don't know why the guys (especially round here) are so hung up on the 44,s. Cause from what I've seen they aren't really all that and a bag of chips,and at the end of the day they're still a sissy a$$ .5 ton axle.
In the subject if 37"s on a 2.5L. They don't make a gear low enough that'll make the 4 popper adequate by any stretch of the imagination.
Krochus is offline
post #13 of 21 Old 09-22-2010, 07:25 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
To answer your question, grab em up and run them full width. The setup in the J truck is a fairly strong setup.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #14 of 21 Old 09-22-2010, 08:50 AM Thread Starter
DDT3
I
What gear would be my best option? I dont really care if I cant go over 60mph. I am setting up the jeep for hunting, mud and putting around the farm.
DDT3 is offline
post #15 of 21 Old 09-22-2010, 09:53 AM Thread Starter
DDT3
Also why cant I attach a pic on here. When I click insert image it asks my for a web address type thing. I just cant attach a image from my pics on my computer?
DDT3 is offline
Rubi swap / Axle swap (merged) tjmike TJ Wrangler Technical Forum 5 06-10-2010 02:04 PM
d30 yj to tj axle shaft or full axle swap? Rocky_Cosmark YJ Wrangler Technical Forum 3 02-14-2010 11:48 AM
Gathering parts for Axle swap, SOA, and V8 swap... tank29 YJ Wrangler Technical Forum 7 12-03-2009 03:42 AM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 04:28 PM
Cutting old axle brackets...need advice! jackal TJ Wrangler Technical Forum 3 04-04-2005 11:49 PM
