Axle swap - Page 3 - JeepForum.com
post #31 of 31 Old 10-21-2002, 11:52 AM
Gator
Just out of curiousity, why is Rockwells overrated ?
if your planning on running bigger than 38's.. a hell of alot cheaper than building a set of Dana 60's, alot stronger, & very versitile, since the axle tube is square, it can be adapted coils or leaf springs fairly easily
dana 60 front weighs about 550 Lbs, Rockwells almost 650Lbs...
not alot of difference
Gator is offline
possible 318 swap and axle swap out of a dodge ihategp YJ Wrangler Technical Forum 8 12-20-2009 02:50 PM
Gathering parts for Axle swap, SOA, and V8 swap... tank29 YJ Wrangler Technical Forum 7 12-03-2009 02:42 AM
Gear Swap or Axle Swap? Zazoos YJ Wrangler Technical Forum 3 06-02-2009 11:29 PM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 03:28 PM
Engine 4.3L swap and axle swap abrupt11 YJ Wrangler Technical Forum 14 02-18-2005 11:14 AM
