Axle swap - JeepForum.com
post #1 of 11 Old 03-04-2013, 11:00 AM Thread Starter
Exit93
Axle swap
I've been looking for a while now and i cant find anything about it but does anyone have a write up on a Dana 35 swap?
Exit93 is offline
post #2 of 11 Old 03-04-2013, 11:03 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Dana 35 swap to?
Luck Favours The Prepared
Anticanman is offline
post #3 of 11 Old 03-04-2013, 12:26 PM Thread Starter
Exit93
To another 35
Exit93 is offline
post #4 of 11 Old 03-04-2013, 12:31 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Take the old one out.
Put the new one in
Bleed the brakes.
You may have to swap yokes if its crossing the 1993/4 line for the swap because of different ujoints.
post #5 of 11 Old 03-04-2013, 12:36 PM
laffman
Or use a 1310/1330 conversion U-joint. That's what I did when I swapped in D30/D35 from a 4 banger YJ to get the 4.10 gears. '95 axles into a '90 YJ.
1990 Jeep YJ Laredo 4.2 I-6
2010 Jeep JK Islander 3.8 V-6
1982 Jeep CJ-8 Scrambler 304 V-8
laffman is offline
post #6 of 11 Old 03-04-2013, 12:37 PM
SeanB95YJ
Just a point to ponder (and if I don't ask you, someone else on here will be sure to )
why?
I mean, unless you're getting the "new" 35 for cheap/free, if you're going through the trouble to replace your axle, why not go for something with a better reputation at strength and reliability? (XJ Dana 44, Explorer 8.8, etc)
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #7 of 11 Old 03-04-2013, 12:53 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I'm guessing the swap is because the OP broke the stock rear end.
post #8 of 11 Old 03-04-2013, 01:04 PM Thread Starter
Exit93
I'm getting it for $100. The po had the rear regeared but not the front. I'm not doing and crazy 4wheelin, I just would like to have it in case I ever need in, line in a snow storm or on some trails
Exit93 is offline
post #9 of 11 Old 03-05-2013, 08:21 AM
Flajeeper1
1987 YJ Wrangler
$100 is a normal price for a D35. I don't understand, do your axles have different gear ratios?
Flajeeper1 is offline
post #10 of 11 Old 03-05-2013, 11:58 AM Thread Starter
Exit93
Yeah my front is 3.07 and I don't know what that back is but I know its not 3.07. I just picked up at Dana 35 with 3.07 for $100.
Exit93 is offline
post #11 of 11 Old 03-05-2013, 02:19 PM
1hand
If you want another one I got one here with 3.07's for $100
Project "Bugout"
1hand is offline
