axle snubbers - JeepForum.com
post #1 of 8 Old 09-14-2011, 11:00 AM Thread Starter
jeep16
axle snubbers
does anybody know where i can get a set of axle snubbers for my jeep. it has about a 3 inch lift on it and the PO didnt put the snubbers on.
jeep16 is offline
post #2 of 8 Old 09-14-2011, 11:10 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
You can check Daystar to see if they carry what you want:
http://daystarweb.com/productlisting...x=9&search.y=8
Joe Dillard is offline
post #3 of 8 Old 09-14-2011, 11:10 AM
Louie4
I think this is for front and rear.
http://www.quadratec.com/products/16054_30X_PG.htm
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #4 of 8 Old 09-14-2011, 11:15 AM
04WJny
1987 YJ Wrangler
Front
http://www.quadratec.com/products/52449_5205.htm
Rear
http://www.quadratec.com/products/52449_5204.htm
There the stock ones so you would probably have to make your own extensions, shouldn't be a problem with some rectangular tubing and longer hardware between the bumpstop bracket and the frame. or you can make something like this:
http://www.quadratec.com/products/16059_50.htm
2004 WJ I6 4.0L DD
1987 YJ I6 4.2L Weber 34 DGEC carb, 4in RC, Custom 1 inch BL,Custom Steering box skid, homemade rear bumper with tire carrier, 33x12.5x15 KM2's on
Cragar Soft 8's, and a few other things
In the process of putting in an 8.8, d30, 4.10's, SOA, and a homemade belly up skid
04WJny is offline
post #5 of 8 Old 09-14-2011, 11:48 AM
fratis
fratis's Avatar
the polyurethane units will look cool for awhile. then they will crack/ fade and fall apart. i have my oem units and they are perfect still. before i had any money i took them out and cut angles in them to look like the poly units.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #6 of 8 Old 09-14-2011, 02:56 PM
Louie4
My stock ones are still good. I'm thinking about putting a 1" shim in between them and the body. As of now the drag link at the pitman arm touches the tie rod on full compression.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #7 of 8 Old 09-14-2011, 03:01 PM
jbolty
jbolty's Avatar
I got a set of bump stops at the junkyard from a chevy luv pickup. They are about 3/4" taller than the stock yj front stops and the mounting holes almost line up.
jbolty is offline
post #8 of 8 Old 09-15-2011, 05:12 AM
CJ51973
CJ51973's Avatar
I am running rear XJ snubbers on the front & front YJ snubbers on the rear. I repositioned them so the would be more in line with where the axle will hit with the longer sprins 7 shackles. These are rubber stock type so they are cheaper too. Check eBay.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
Snubbers Parts Name MCanavan TJ Wrangler Technical Forum 10 01-17-2015 08:14 AM
Tire snubbers Rubikahn Wrangler General Discussion 2 03-10-2010 08:31 PM
Whats the purpose of YJ wrangler axle snubbers maiossa YJ Wrangler Technical Forum 13 04-09-2009 09:44 PM
Tire snubbers condor YJ Wrangler Technical Forum 2 02-07-2008 03:11 AM
JKS Snubbers MCanavan TJ Wrangler Technical Forum 8 04-23-2006 06:34 PM
