axle seals - JeepForum.com
post #1 of 6 Old 04-20-2013, 03:22 PM Thread Starter
jhrebs
1987 YJ Wrangler
axle seals
So my right front axle seal is leaking. I found like 5 different seals. Any idea which ones i need? I prefer using Quadratec. I might as well do both the right and left. Any other things I should do or look at while I have the axle torn apart? How big is this job? What am I in for?
'87 reg. historic, 2" bds springs, 1" boom shackles, 1" daystar BL, 31" Intereco trxus, Crager soft 8's, steel braided brake extensions, monsta liner
jhrebs is offline
post #2 of 6 Old 04-20-2013, 06:31 PM
Dake
Dake's Avatar
Dake is offline
post #3 of 6 Old 04-21-2013, 06:50 AM Thread Starter
jhrebs
1987 YJ Wrangler
Does it make sense to do both at the same time? What about doing the bearings while I am there?
jhrebs is offline
post #4 of 6 Old 04-21-2013, 08:45 AM
jbolty
jbolty's Avatar
The right front seal is not a hard job, but is frustrating because getting access and getting the seal in straight is a chore; buy a couple extra. As for the drivers side, you need to remove both axles and the carrier to change that one; leave it alone unless it's leaking.
jbolty is offline
post #5 of 6 Old 04-21-2013, 05:29 PM
pasinbuy
Good advise.
Buy three seals in case you wreck them. Expect it. You can return the seals that you do not use.
Do a search on replacing the front seals. It is a frustrating job but very doable.
If you see any leaking on the driver side now will be the time to replace it. If no leaking just leave it alone.
If you do have to replace the driver side seal now would be a good time to throw in a Aussie Locker.
pasinbuy is offline
post #6 of 6 Old 04-21-2013, 06:09 PM Thread Starter
jhrebs
1987 YJ Wrangler
Thanks guys. I will just do the passenger side. But great thinking on the Aussie. Since I have to remove the gears anyway, might as well!
jhrebs is offline
