Axle Ratio Help - JeepForum.com
post #1 of 23 Old 04-19-2012, 03:08 PM Thread Starter
87yjrad
Axle Ratio Help
I have changed out the old Peugeot tranny to an AX15 and matched that up to a NP231 transfer case. Now my axle gearing is way too high. I have 3.09:1. The ratio calculators I have found
http://www.grimmjeeper.com/gears.html
with 33" tires say a 4.10:1 ration would be just about right. I found front and rear axles off a 95 YJ, Dana 30 and 35. They should bolt right up. The guy says they are 4.10 ratio but how do I verify that. His price is right and this is a cheap way to change out my gearing. Please don't tell me to go to a different axle I'm not ready to do that. I just want to get my gearing where it should be and this is the cheapest way to do it. I wrote down the numbers as best I could off the D30 tag, but can't find a way to identify them. I have to make sure of the ratio before I buy them.
52068372
10610461
those are the numbers off the d30 tag. Does anyone know how to read them? or is there another way to do it without pulling the cap?
Thanks!
87yjrad is offline
post #2 of 23 Old 04-19-2012, 04:07 PM Thread Starter
87yjrad
okay, so I just found an old thread, took me a while. Says if the engine was 2.5L 4 cyl, which it was and has manual tranny which it did, then the axle ratios will be 4.10. Auto tranny was 3.73. Cool, so it looks like these axles will get me right where I want to be.
So as far as the spring perches, shock mounts, brake lines and everything else they should match right up? Right?
87yjrad is offline
post #3 of 23 Old 04-19-2012, 04:15 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Your search results are correct. The 2.5L manual shift YJs had 4.10 gears.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 23 Old 05-01-2012, 07:56 AM Thread Starter
87yjrad
a little more help guys. I bought the d30 and d35 from the guy who said they were 4.10. So I pulled the covers off both. The front D30 ring gear is stamped P8L164 41 10. The rear D35 is stamped P8L821 37 9.
Does that mean I have two different gear ratios? That won't work will it? Dang it.....
87yjrad is offline
post #5 of 23 Old 05-01-2012, 08:02 AM
RowJ
Means ring teeth and pinion teeth count.....
Different gearing won't work, but not sure you have different.
RJ
RowJ is offline
post #6 of 23 Old 05-01-2012, 08:05 AM Thread Starter
87yjrad
sorry guys, I'm still learing
41 / 10= 4.10
37 / 9= 4.11
I guess they are the same ratios. So because the ring gears are different sizes right? That's why the tooth count is different to get the same ratios?
87yjrad is offline
post #7 of 23 Old 05-01-2012, 11:40 AM
pariah24
Correct. One axle ratio will always be a little off. 3.54/3.55 4.10/4.11, etc. The reason for the very slight differences in axle ratios like 4.10 and 4.11 is because of the slight ring gear diameter difference between the front and rear axles. It's just not cost effective for the gear manufacturers to try and make the ratio exactly the same since that slight .01 or so difference doesn't affect anything.
pariah24 is offline
post #8 of 23 Old 05-01-2012, 12:56 PM Thread Starter
87yjrad
Thanks! I'm gonna slap those axles on here soon.
87yjrad is offline
post #9 of 23 Old 05-09-2012, 08:24 AM
voz
Piggy Backing on this thread..
I just picked up a 8.8 3.73 limited slip rear for my 89, in great condition.
Question. I just spent alot of money on the front, hub bearing, tie rods , ball joints etc..
what re-gearing kit {if such a thing) is needed to get my front at 3.73 gearing..
Thanks in advance..
VOZ™
voz is offline
post #10 of 23 Old 05-09-2012, 08:50 PM
94chb
52068372
10610461
Thanks!
its 4.10 look at the bottom set of number and in front of that 10610461 (if you clean it more and read) it will be 4.10610461
you can also open the cover up and on the ring gear will say the tooth count Example 40 10 divide the numbers and it will tell your ratio for example its 40/10= 4.10
here is a pic of my Ring gear. see the 41 11 41/11= 3.73
94chb is offline
post #11 of 23 Old 05-09-2012, 09:58 PM
idskot
Not to completely thread jack, but I was planning on buying / installing an 8.8 and regearing it to 4.11. My question is, as this is my DD, will I be able to drive around with stock gearing up front as long as I don't put it in 4wd?
idskot is offline
post #12 of 23 Old 05-09-2012, 10:09 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Definitely.
Pull the front driveshaft out, just to avoid an accidental engagement if you want to.
Max
Mean Max is offline
post #13 of 23 Old 05-10-2012, 06:25 AM
idskot
Originally Posted by Mean Max View Post
Definitely.
Max
Awesome. Thank you, Max.
idskot is offline
post #14 of 23 Old 05-10-2012, 06:36 AM
gunshw301
Be patient and find one with 410 gears from the factory. Don't regear to a ratio that can be found with a little effort, it will save a good deal of money.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #15 of 23 Old 05-10-2012, 01:50 PM Thread Starter
87yjrad
wow this thread is going off in all different directions. Okay guys, help me out a little now. I am going to tackle this change over this weekend. I have opened up both axles and drained oil. Both front and back were full of dark gear oil, no leaking seals. Everything looks good. I do need to pull the brake calipers from my existing front axles and move them over to the new axles. They should bolt right up? No changes from 87 to 94 that is going to give me problems?
Also, I will probably be doing this by myself as I do with most everything on my jeep. I have two sets of good axle stands, two good bottle jacks and a light duty, scissor type tranny jack. Anybody have a good way to drop these axles and get the new ones in, one person type of procedure? Thanks for any advice!
87yjrad is offline
Axle ratio cgbgator TJ Wrangler Technical Forum 5 02-15-2011 12:21 PM
can you tell axle ratio from vin#? monkers TJ Wrangler Technical Forum 15 06-06-2010 09:54 PM
Sahara - Axle locker? Axle ratio? Meir10 JK Wrangler Technical Forum 8 02-25-2007 02:15 PM
Axle Ratio CyBerAliEn JK Wrangler Technical Forum 11 01-20-2007 09:57 AM
What is 3.73:1 Axle Ratio??? jaguar18 TJ Wrangler Technical Forum 3 03-16-2004 03:10 PM
