Axle Questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Axle Questions
Black Friday Sale - Deep Discounts from ExtremeTerrain.com6th Annual, Beat Your Wife to the Credit Card Sale!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread Yesterday, 04:08 PM   #1
Hayden_S
1987 YJ Wrangler
Axle Questions
Found a good deal on a dana 30 and 35 with 4.10 gears out of an 89. I'm looking to put them in my 87 because I have a bent axle shaft. I can pick both of these up for the price of what it will cost me to replace my bent axle shaft. So I would be solving the problem of the bent axle, as well as upgrading to the 4.10 gears. Just wondering if everything should bolt right in. U joints and everything else the same size? I realize the dana 35 is a weakpoint but don't have the money to go with an 8.8 or 44
Hayden_S is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 05:25 PM   #2
uhohthe50
Should be a direct swap. I think 95 was the only different year where they went to larger Ujoints on the front axle.
My 1990 YJ Build Thread: http://www.jeepforum.com/forum/f22/might-well-start-build-thread-now-my-1990-yj-1291174/
uhohthe50 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 07:14 PM   #3
1320yj
The 94-95 does have a larger U-joint but there is an adapter U-joint available that has one side of the cross smaller than the other side.
The joint is readily available at most auto parts stores.
1995 2.5 5Speed SOA 33x12.50 Mud Rovers
1320yj is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 08:40 PM   #4
Hayden_S
1987 YJ Wrangler
Thanks for the replies. Probably gonna jump on them then. Will come to y'all if I have any more questions
