Axle question? - JeepForum.com
post #1 of 9 Old 11-24-2011, 07:06 PM Thread Starter
rockcop
Axle question?
What year(s) explorer 8.8 axle will fit without modification under a YJ? How can I tell what gear ratio is in my axles without removing the rear cover? Thanks. Hope everyone had a good Thanksgiving.
rockcop is offline
post #2 of 9 Old 11-24-2011, 07:23 PM
soonermatt
These are all really common questions which have been answered thousands of times before. I, respectfully, suggest you try the search.
soonermatt is offline
post #3 of 9 Old 11-24-2011, 07:29 PM Thread Starter
rockcop
I'm lazy and find it easier to just ask. LOL. Point taken. I'm new to the forum And have searched. I am looking for confirmation and thought I would throw the axle question in while asking the ratio question.
rockcop is offline
post #4 of 9 Old 11-24-2011, 07:50 PM
dillonjm
2013 WK
If there is no tag on the diff cover anymore then I would do the following.
Jack up the rear end, transmission in neutral, rotate the tire one rotation and count how many times the driveshaft rotates.
The number of driveahaft rotations to one wheel rotation is your gear ratio.
Count the ring gear and pinion gear teeth. Divide to get gear ratio.
And the 8.8 will need you to reweld the perches to do it right. They aren't bolt in. Lots of threads on this topic. Should be able to find all the info ya need in a couple min. It's definitely a pretty easy swap. 95+ is the desireable years because of disk brakes
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #5 of 9 Old 11-24-2011, 07:55 PM
Xpress
Exploder 8.8's aren't bolt in. There are companies that weld on new perches and stuff, but otherwise stock 8.8's aren't bolt in.
All about that unibody life.
Xpress is offline
post #6 of 9 Old 11-24-2011, 08:19 PM Thread Starter
rockcop
If I get a older axle with drums, is it as simple as remounting perches?
rockcop is offline
post #7 of 9 Old 11-24-2011, 08:20 PM
timatoe
timatoe's Avatar
Well, there have been guys that simply bolted them in, but I wouldn't go that route. Perches are cheap, grind the stock stuff off and weld new ones on were they need to be, plus shock tabs, that about covers the welding, everything else from there is pretty easy. The differences in brakes really have no bearing on install.
timatoe is offline
post #8 of 9 Old 11-25-2011, 01:39 AM
castorriver
Use the search box at the upper left of the screen. Using the search tool located on the middle-right just doesn't give as much info. When I figured that out I got better results.
Registered Nurse Jeep Club Member #1 (I think...)
Verse 36: And He said to them, "But now, whoever has a money belt is to take it along, likewise also a bag, and whoever has no sword is to sell his coat and buy one.
castorriver is offline
post #9 of 9 Old 11-25-2011, 01:57 AM
94chb
WE just answered everything a couple posts below yours.
http://www.jeepforum.com/forum/f12/rear-1291374/
94chb is offline
