Axle identification tags question - JeepForum.com
post #1 of 12 Old 11-26-2008, 09:02 AM Thread Starter
spshultz
1987 YJ Wrangler
I just need to verify whether I'm correct or not.
I went out this morning and scraped all the crud off my axle tags.
I think I have 3.54 gears but would like to make sure.
Front tag:
3 54 46-13
8953003710
Rear tag:
55 605295-6
8953004684
The Front tag numbers I think I understand (3.54 13/46=3.54). But I don't understand the rear tag number. The Front has to be the same as the back anyway so I'm positive the back is 3.54 also but not sure how to read those numbers. Or are the rear gear ratio numbers somewhere else other than the tag?
Thanks!
Shawn
spshultz is offline
post #2 of 12 Old 11-26-2008, 09:13 AM
pointech
2014 JK Wrangler
According to the Wiki, you either have 3.07 or 3.54 since you have a 6 cylinder. Based on the tag, I would assume you are correct but I don't know for sure. Actually I think the front is 3.54 and rear is 3.55 (close enough that it doesn't hurt your TC).
pointech - Tom in Virginia
2014 Wrangler Sport
SOLD 1994 Wrangler YJ S - 4 cylinder 5 speed -
SOLD 1997 Jeep Wrangler TJ SE
pointech is offline
post #3 of 12 Old 11-26-2008, 01:48 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Go here to this site.
http://www2.dana.com/expert/wc.dll?cvsp~deabill~2~
This is on Dana's website, and it is the BOM (Bill Of Materials) search that will decode the numbers on your axle. It will tell you EXACTLY how your axle was setup as it was delivered to Jeep for vehicle prodution.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 12 Old 11-26-2008, 08:41 PM Thread Starter
spshultz
1987 YJ Wrangler
Cool. Thanks Mean Max. I can find the BOM on the rear. Definitely 3.55. But I can't find anything for the front. And that's OK. I just really just wanted to verify my gear ratio and it's 3.54 Front / 3.55 Rear. And that's good enough. I probably won't go any larger than 31" tires since the speed limit out here is 75 and most everyone does 80.
spshultz is offline
post #5 of 12 Old 11-26-2008, 08:45 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
No problem!
I hear you on the road speed deal. I have 33's on 3.07 gears & I haven't used 5th gear in over 2 years! I top out my speed at about 55 MPH, and although it'll go faster, I don't because my MPG drops off by about a 1/3 over 55!
Mean Max is offline
post #6 of 12 Old 08-04-2009, 11:41 AM
OPlo
1987 YJ Wrangler
Where can I find the BOM. Here's what I wrote down (after also removing several layers of grease and dirt). I Can't find any matches to these numbers on the Dana site. I'm guessing this is all stock. Some numbers tough to read, may be wrong...
Front Diff
42106
091 6
Rev 0
11-13-85
Rear Diff
40869 - did find this "cover" part on the Dana site.
235 6
Rev C
7-24-85
Also printed vertically on the front differential cover along the left edge
8953003710 - is this the BOM? - Dana site returned 7 results for this number but none of the diff case kits matched mine??
3 54 46 18 (gear ratio again here? i'm betting I mis-read that 13 as an 18. 46/13 = 3.54)
Thanks for any help.
OPlo is offline
post #7 of 12 Old 08-04-2009, 12:01 PM
5-90
5-90's Avatar
1988 XJ Cherokee
Front Diff
42106
091 6
Rev 0
11-13-85
Rear Diff
235 6
Rev C
7-24-85
3 54 46 18 (gear ratio again here?)
Looking at the cover side of the axle (rear if rear axle, front if front axle,) you should be able to find the BoM number stamped into the right-hand tube (as you're looking at it.) The BoM number is typically six digits, and should start with a "60" or "61" - with a one- or two-digit suffix appended after the six-digit "basic" BoM.
"8953003710" looks like a ChryCo part number.
Also note that if you have hexagonal rear axle cover, with the hex sitting on a flat side, you won't have a Dana axle. That would be a ChryCo 8.25" axle instead. It's actually not a bad axle, but does suffer from being a C-clip.
Also note that just about all Dana axles will have the model number cast into the reinforcing webs to the tube sockets - so if you have a D35, you should see "35" cast in those locations. If you have "35C," that doesn't necessarily mean C-clip, it simply means "Custom" - which indicates that the axle was not shipped as a whole assembly (it was shipped as a bare housing, final assembly to be done by the vehicle builder.)
The 242ci six typically came with 3.07:1 gearing for the manual transmission (which is wretched) or 3.55:1 gearing for the AW4 automatic (which isn't bad, out to 31" tyres.)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #8 of 12 Old 08-04-2009, 12:13 PM
OPlo
1987 YJ Wrangler
Thanks. I'll look for this (degreaser in hand).
"8953003710" looks like a ChryCo part number.)
Is that possible? 87 was still AMC right?
Also note that if you have hexagonal rear axle cover, with the hex sitting on a flat side, you won't have a Dana axle. That would be a ChryCo 8.25" axle instead. It's actually not a bad axle, but does suffer from being a C-clip..)
Pretty sure they are both Dana. They both have the Dana diamond shaped logo stamped on them.
Front looks like this: http://www.jeepforum.com/wiki/index.php/Dana_30
Rear looks like this: http://www.jeepforum.com/wiki/index.php/Dana_35
Great. I'll look for thses as well.
I have the 258, I6 - 33" tires. Thus I'd like to know what my ratio actually is. From what I'm reading my gear ratio is too high. If I'm just tooling around town I guess I'm OK. 4-wheelin' might be a problem though.
OPlo is offline
post #9 of 12 Old 08-04-2009, 04:36 PM
OPlo
1987 YJ Wrangler
Found both BOMs. Had to get out the wire brush.
Front: 610281-3, 3.54 gear ratio
Rear: 605295-7, 3.55 gear ratio
According to the Dana site the gear ratio is slightly different. Is that possible?
Couldn't find the 30 or 35 stamps - but - on the front diff cover, the following was stamped at three corners (facing front of vehicle): lower left: RM, lower right: 3, upper right: 253. Any clue what these are?
OPlo is offline
post #10 of 12 Old 08-04-2009, 05:57 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Yep, they can be slightly different. The 2.5L YJ's (most) have 4.11 front & 4.10 rear, IIRC. It's an insignificant amount.
Max
Mean Max is offline
post #11 of 12 Old 06-30-2012, 01:05 PM
weerwolv
VERY CONFUSED? YJ Brake change vs BOM from Dana online
Hi all,
I have a 1993 YJ Sahara that had 3.07's in it from the factory and ABS brakes.
Purchased what I thought were matching used Dana 30 and 35's from another 4 cylinder YJ that was identified as having a 4.10's
Here is where is get's confusing.
After getting the axles rebuilt I take a hard look at the brakes on the D30 I got from the other YJ vs my original and realize they ARE different. The caliper doesn't look remotely similar. I do a bit of research and find out that the replacement axles have the 87-89 brake setup which is different than what I have and have a BOM of 610323 so they come from from a 1989 setup.
Even more of a confusing problem is the rear axle which appears to be from a 1994 YJ 4 banger and has a BOM of 615661-2.
So I've had both axles gone through by a friend and they are in great shape for what they are.
Is there an issue using the older brake setup with a newer YJ? Everything looks the same except the knuckles, calipers and of course the Vacuum Disconnect cover hookup which I'll need to swap over from my older axle as the line plug is different.
Is this an issue and were the older brakes better than the newer setup or were they just different?
Thanks all.
weerwolv is offline
post #12 of 12 Old 06-30-2012, 02:16 PM
Kevinyj95
Why dont you just jack the car up on all fours and chalk the tires and turn the drive shaft? Easy way to tell what gears you have. Look it up on youtube.
Kevinyj95 is offline
axle identification 30/35/44 groundhound TJ Wrangler Technical Forum 9 06-12-2009 01:04 PM
Axle identification treefiddyYJ YJ Wrangler Technical Forum 16 05-10-2009 10:55 AM
Axle Identification Douglas S. YJ Wrangler Technical Forum 13 02-07-2009 09:29 PM
Axle Identification kwikshift YJ Wrangler Technical Forum 27 04-06-2007 07:55 PM
Axle Identification 5150 TJ Wrangler Technical Forum 13 02-23-2004 05:19 PM
