Axle help!!! - JeepForum.com
post #1 of 3 Old 12-20-2001, 12:12 PM Thread Starter
gojurick
gojurick's Avatar
Axle help!!!
Here goes. Not being the extreme mechanical type, I thought the wrenchheads here could help. I went to drive my 92 YJ the other day, after about a month of sitting, and it would not go. Starts fine, will not move. You can tell the power is there, the vehicle was rearing back. I fugred it was rear axle related, so I jacked and racked it, took it out of gear, no brakes and spun the driver's rear tire, spins ok. Rear passenger tire is locked, will not turn more than an inch or so either direction. Any ideas ? Before I drag it (literally) down to the local 4x4 shop, I want to know if it's something I can possibly tackle. I can work a tool or two, but I'm not going to take on an axle replacement or something of that nature. If it matters, it's a stock 35c, no locker, 4.10 gears. Thanks for any assistance people.
'92 YJ, SOA w/ 35x12.5 X-terrains,RE quick-discs, Warn HS9500i, Detroit Electrac rear, ARB front, 4xDoctor rocker guards, AGR Steering, Borla Header & exhaust, Atlas II
Many bloody knuckles, Best of all, my wife luvs it too!!!
***Coming soon*** Chevy 350 V8 swap
gojurick is offline
post #2 of 3 Old 12-20-2001, 01:59 PM
Newfie
Was the park brake on while it was left parked for a month? If it was, it's prolly seized/stuck, not a big job to free it up. HTH
No officer, that wasn't an accident. I did that on purpose...
Newfie is offline
post #3 of 3 Old 12-20-2001, 02:12 PM Thread Starter
gojurick
gojurick's Avatar
Yes, the PB was on for the month. I'll look into that as a possibility. Thx.
gojurick is offline
Superior Axle's new axle Super Truss kit installed, beef up your axle for only $399 Jerry Bransford TJ Wrangler Technical Forum 164 01-09-2015 11:14 AM
Should the Front Axle & Rear Axle be off centered to the passanger side by .5"? Lemmiwinks TJ Wrangler Technical Forum 3 07-07-2009 09:27 AM
Superior Axle & Gear EVOLUTION SERIES Front Axle Tube Seals 95wrangler4life YJ Wrangler Technical Forum 3 02-17-2009 02:00 PM
What is the difference/benefit of a high pinion axle compared to a regular axle? bhicks TJ Wrangler Technical Forum 7 09-10-2008 03:32 PM
