Axle Gearing Decision-What would you recommend? - JeepForum.com
post #1 of 22 Old 08-08-2013, 06:16 PM Thread Starter
weerwolv
Hi all,
Currently running on swapped D30 and D35 axles, both running the 4.10 gears.
I have a 4.0 with the AX15 and running Toyo MT 33x10.5 tires on 15" wheels
Getting ready for a big axle swap project and want to do it right
Maximum tire size I will ever run is 35" as I need to put this on the road 60 percent of the time with wheeling 40 percent of the time and don't want to go crazy.
I've decided on a Crate D44 built with the ARB locker already installed on 35 spline shafts.
I'm now stuck on what to do gearing wise. The 4.10 are OK for a DD rig on 33's but I can see how useless they would be for 35" tires
4.88 seems to be where everybody says you should be for 35's for the best offroad rig. That sounds good but I need to be on the highway from time to time.
4.56 seems like a good compromise as it'll make my 33's work better and leave me the option to go to 35's in the future without gearing again.
Got to regear the D30 for this project so I only want to do it once.
I live in New England so we don't have the engine elevation issues some of you folks have so I'm thinking 4.56 is my best choice. Any thoughts and recommendations?
weerwolv is offline
post #2 of 22 Old 08-08-2013, 06:28 PM
dillonjm
2013 WK
I liked the 4.88s on the highway too, I hardly ever had to downshift out of 5th, which was nice, but 4.56s would work about the same.
You'll be happy with either one.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #3 of 22 Old 08-08-2013, 06:31 PM
rykemc
I am running 4.56's with 35's. 4.0, well actually a 4.6 stroker, AX15. I love the way my jeep does both on the paved road and not paved road. I DD my jeep and do see some overpasses on my daily drive to and from work. I am in West Texas so it is flat land but we do have wind from hell. I can cruise in 5th gear, 70mph(GPS confirmed) turning around 2200-2300RPM and not have a problem with power. I think for what you want out of your rig, mostly DD and some trail time the 4.56 will be great.
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #4 of 22 Old 08-08-2013, 07:23 PM
calvynandhobbs
calvynandhobbs's Avatar
I ran 4.56s in my TJ w/4.0 and AX15 and 33s. They were nice, but I wanted a little more low end grunt and I'm also going to 35s on the YJ so I've got a set of axles with 4.88 gears ready to go in. I actually have 2 sets. One set up SUA and the other SOA, both with 4.88 gears already in them. Deciding which way I'm going to go.
94 YJ - work in progress
calvynandhobbs is offline
post #5 of 22 Old 10-31-2013, 02:23 AM
Gausswave
I hope this isn't too much of hijack but I'm in a similar quandary. Looking to run a 33-35" tire. Online calculators suggest 3.73 is a better stock match. Driving wise I'll be 70/30 the 30% off road in the pacific NW. No real rock crawling but I do end up fighting wet heavy snow on the west cascades in the winter. I'm a transmitter engineer so I get paid to play! After reading this it seems the practical wisdom suggests even 4.10's might be a bit high?
Gausswave is offline
post #6 of 22 Old 10-31-2013, 03:44 AM
zte87
GIVE IT THE ONION
zte87's Avatar
Unless your running v8 power I dont think 3.73 would be wise, I would run 4.10 min! And thats coming from another pnw resident!!
zte87 is offline
post #7 of 22 Old 10-31-2013, 06:27 AM
StanF
Buying a crate axle sounds awesome!
Would 4.88s give you a "little" better crawl ratio when offroad? That might be helpful, depending on the type of offroading you do (rock crawling, etc). For mudding, you probably want 4.56.
StanF is offline
post #8 of 22 Old 10-31-2013, 06:54 AM
calvynandhobbs
There would be a slight different, but not a lot. When I went from 3.73s to 4.56s in my TJ on 33s the crawl ratio was very noticeable. I could go up some inclines without any gas and made rock gardens much easier to navigate without using nearly as much clutch, brake or gas pedal. I liked the ratio so that is why I'm going to 4.88s on my 35s.
post #9 of 22 Old 10-31-2013, 07:22 AM
Siva283
No one seems to have mentioned the difference between 4.56 and 4.88's is only 2 or 300 rpm's on 35's.
Ask me how I know...
Siva283 is offline
post #10 of 22 Old 10-31-2013, 07:35 AM
calvynandhobbs
It's not much difference at all. My opinion is that if you're paying for regearing go ahead with the 4.88s. The installation cost is the same if you're paying someone else to do it. I got lucky when I had my TJ and found a used set of axles to swap in that had 4.56 gears for less than half the cost to have someone regear and i got lucky again and found a D44/8.8 with 4.88 gears already installed to swap into my YJ.
post #11 of 22 Old 10-31-2013, 07:48 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Go lower than you thought originally. Better to be screaming on the freeway than bogged down.
Luck Favours The Prepared
Anticanman is offline
post #12 of 22 Old 10-31-2013, 08:14 AM
Siva283
This is my thought. If a couple hundred RPM's are gonna break you then you need to rethink your gear choice. Go with 4.88 and thank me later
Siva283 is offline
post #13 of 22 Old 10-31-2013, 08:49 AM
jserna
1987 YJ Wrangler
What about a non overdrive tranny?
jserna is offline
post #14 of 22 Old 10-31-2013, 11:19 AM
Sparrows
Again, not to hijack, but I'm having a similar quandary...
Jeep 2.5, 35s, ax5(ax15 future).
5.13 or 5.38? I know conventional wisdom is you can't over-gear the 2.5, but I also DD and plan on some 1k+ mile road trips. I want to be able to comfortably cruise 75 all day long.
Thanks for putting up with my mini-hijack.
Cheers
June '13 YJOTM
Sparrows is offline
post #15 of 22 Old 10-31-2013, 11:42 AM
zeus87gn
1987 YJ Wrangler
Your profile says you have the 4.2
If your tires are going to be 33', then yes - 3.73s are just right
If you plan on 35s, then definetely 4.10s
I originally wanted 3.73s for 33" tires - I was talked into 4.10s
the 33s are ok with the 4.10s, but I need a 6th gear for the highway
and I don't use 1st much
I plan on going to 35s in the future
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
