axle disconnect question - JeepForum.com
post #1 of 3 Old 03-08-2014, 08:21 PM Thread Starter
dodgedad94
On my 89, the vacuum actuator went out and all the vacuum lines removed before I bought it. Instead of replacing the vac lines, I installed a push/pull cable to lock the axles. Is there any danger or inherent issues with leaving the axles locked on a permanent basis?
94 ZJ
89 YJ
dodgedad94 is offline
post #2 of 3 Old 03-08-2014, 08:26 PM
johnboy68
HIP2BSQR
johnboy68's Avatar
Not at all. Folks do it all the time. If you notice vibrations at higher speeds, you may want to get your front drive shaft balanced.
-John-
johnboy68 is offline
post #3 of 3 Old 03-08-2014, 08:32 PM Thread Starter
dodgedad94
Ok. Thanks for the info johnboy. I've found that it is a pain to engage/disengage unless you hold your mouth right, the planets are in perfect alignment, etc.
94 ZJ
89 YJ
