axle ? - JeepForum.com
post #1 of 6 Old 10-26-2001, 04:35 PM Thread Starter
zuck2001
axle ?
Which is a better swap, a dana 44 out of an 87 XJ or a ford 8.8? I found the 44 for $225, its complete except for the brakes.
'89 YJ w/ 4.2L I-6, 2.5" Rancho SL, 2" BL, 1.25" SHKLL, Uniden CB, 2 JL Audio Subs and Banpass box with a 300/1 2 channel Earthquake Amp, 33X12.5 Cooper S/T, no sway or trac bars, no bump stops, 2 titanium KC's.
zuck2001 is offline
post #2 of 6 Old 10-26-2001, 06:43 PM
jpwranglr9
i personaly like the 44. but i got mine for $60 compleate out of a scout. i put 4.56, disk brakes, and locker. there are more parts for these and ther are somewhat cheeper. i wouldn't pay $225 for a 44 though and all you realy need is the housing, & shafts. most likley you will swop out gears and probably need a new carrier for the gears. Brakes you can go stock or disks.
Its not what you buy...its what you BUILD!!!
1995 YJ ,SOA with 4" procomp front 3.5" BDS rear 1" shackle rear, custom stearing, 35x12.50x15 pro-comp MTs, warn xd9000i, on-board air from A/C, dana 44 rear and 30 front with 4.56, powertrax no-spin rear, custom disks rear/trutrac front, warn front shafts, HD SYE kit, HD front and rear driveshafts, Warn 4X flairs, PIAA 520 ligts and on and on and on :)
jpwranglr9 is offline
post #3 of 6 Old 10-27-2001, 01:29 PM
powjunkie
I ran across an old offroad mag the other day that compared the two and the Ford 8.8 won the contest. It's beefier and has higher a stress rating for shearing. It's something that I'll be adding someday in the future.
94 YJ 4", SYE, 33 mud t's on MT classics; 4.10's with Detroit Truetrac in rear
powjunkie is offline
post #4 of 6 Old 10-27-2001, 04:32 PM
jeffy
jeffy's Avatar
Well, I like the Dana 44 better. There are different flavors of 8.8" Fords. The 28 Spline versions aren't much better then the stock Dana 35c. Then there are the better 31 spline which are the one's to get. The axle tubes are thick, around 3", and the shafts are 1.31" diameter. In comparason the Dana 44's tubes range from 2 3/4" to 2 7/8". Generally rear axles used smaller diameter tubes then the front. The 8.8" from later Explorers come with disc brakes and up to 4.10 gears. I should also note that they have C-clips, prone to having the tubes spin and bearing caps loosening up. That's why many use those pre-load diff covers.
I like the D44 since I plan on replacing my front axle with a Dana 44. Then I'll be able to interchange gears and lockers. Dana 44's are probably the most widely produced axle. The only down side to the XJ Dana 44 is the cost. But at $225, it's a good price. I think you can use the Dana 35 brakes or go with ZJ D35 Disc's.
I don't think you'll find a 8.8" for under $300. Most want $500-900. The biggest advantage of the XJ Dana 44 and Explorer 8.8" is that they are 5 on 4.5" bolt pattern. Meaning you won't need to swap the front axle right away. If you got a Scout axle, then you'd have to consider getting the axle's and drums redrilled to 5 on 4.5" or else swap out the front axle at the same time.
Here's a article on how to swap a YJ and some info on the XJ Dana 44. Getting brackets for a TJ would be the most expensive part I think.
*** www.4BangerJP.com ***
jeffy is offline
post #5 of 6 Old 10-28-2001, 06:32 PM
fuelin
i also like the 44 (as long as its not a tj 44) i dislike the cclips yes the axles are stonger but if i break one in the 44 it the tire will stay on the vehicle.
fuelin is offline
post #6 of 6 Old 10-30-2001, 06:44 AM
jpwranglr9
the TJ's 44 is not a c-clip. the only downside to the Tj's is that it uses a slightly smaller tubbing wall.
Superior Axle's new axle Super Truss kit installed, beef up your axle for only $399 Jerry Bransford TJ Wrangler Technical Forum 164 01-09-2015 12:14 PM
Should the Front Axle & Rear Axle be off centered to the passanger side by .5"? Lemmiwinks TJ Wrangler Technical Forum 3 07-07-2009 10:27 AM
Superior Axle & Gear EVOLUTION SERIES Front Axle Tube Seals 95wrangler4life YJ Wrangler Technical Forum 3 02-17-2009 03:00 PM
What is the difference/benefit of a high pinion axle compared to a regular axle? bhicks TJ Wrangler Technical Forum 7 09-10-2008 04:32 PM
