Axel question... - JeepForum.com
post #1 of 14 Old 04-10-2010, 09:49 PM Thread Starter
stumpjumper09
Axel question...
so i been trying to find some yj axels with 4.10s that i can swap under mine to get rid of the 3.07s since it would bolt right up and be the cheaper route.
well turns out they are hard to come buy so im askin you guys if any other axels will bolt up to my set up like maybe out of a cherokee or a tj? idk?
does anyone know what i can do or what mods ive had to make to get the axels to work?
any imput and suggestion is awesome!!!!
Jeep name = White lightnin!
stumpjumper09 is offline
post #2 of 14 Old 04-11-2010, 12:48 AM
Jedidiah
1995 XJ Cherokee
I just did a search in your area on this website Car-Part.com--Used Auto Parts Market and found a bunch of them.
Jedidiah is offline
post #3 of 14 Old 04-11-2010, 01:02 AM Thread Starter
stumpjumper09
hey man thanks for the website that thing is awesome
but danggg!!! those are spendy! i was looking to spend 300-400 for both not each
post #4 of 14 Old 04-11-2010, 02:29 AM
Allen52105
go for a 8.8 out of a 95 or newer explorer. they will be 4.10 gears. minor work to put this axle in and its STRONG.
find a dana 30 out of any 4 cyl wrangler and it will have 4.10 gears. this set up will be good for anything up to a 35 inch tire
jason
Allen52105 is offline
post #5 of 14 Old 04-11-2010, 02:35 AM
Allen52105
if you want to keep the dana 35
Dana 35 4.11 Wrangler YJ
jason
post #6 of 14 Old 04-11-2010, 07:09 AM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
As I recall, the 4.10 gears in an explorer were only stock in the Sport model, the shorter 2 door.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #7 of 14 Old 04-11-2010, 11:23 AM Thread Starter
stumpjumper09
how hard is it to put in the 8.8? could a novice do it with guidence from you fellas?
post #8 of 14 Old 04-11-2010, 11:58 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
You are correct. I heard something about a 4-door with a factory tow package, but I have never seen one. It took me almost 2 years to find one at the pick and pull with 4.10. Then as soon as I got it home, I decided to go with 4.88.
You will need some welding skills. And it always ends up costing a lot more than just the price of the axle.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #9 of 14 Old 04-11-2010, 12:08 PM
Allen52105
you will want to look for the eddie b. eddition with the v8 and tow package to get the 8.8 w/ 4.10
jason
post #10 of 14 Old 04-11-2010, 12:36 PM
joshbaker92yj
Believe me it always cost more then u anticipate but well worth it in the end. Oh and i just finished the 8.8 swap in my yj and love it.
92 yj, 36 sx swamper, locked d30 and locked 8.8.
on the road again.
joshbaker92yj is offline
post #11 of 14 Old 04-11-2010, 12:40 PM Thread Starter
stumpjumper09
How much did this end up costing you?
post #12 of 14 Old 04-11-2010, 01:11 PM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
That's a hugely variable answer question. Use the old internals or buy new? ...locker? ...which one? ...are the brakes on the used axle good or need replacement? ...gears right ratio? ...bearings good? ...buddy hand you an axle or pay top dollar at a 'they pull it' yard?
Mine was $250 for the axle, $1000 at Randy's (4.88 gears, ARB, master kit), $150 for the JB4x4 steering bracket, $150 or so for rotors and pads, and I did all the labor myself.
Web Admin for
post #13 of 14 Old 04-11-2010, 06:10 PM
joshbaker92yj
The axle cost me 250 and the locker cost 400. Gears and locker setup was about 250. and the gears were 100 and the master install kit was 100ish. SO total it was about $1100. If i were to redo it i would get a spool kit from moser with 35 spline shafts and call it a day. Thats only about $700 with the ford 9inch tube ends because you need those to fit the bigger axles but then u get rid of c clips and c clip eliminators.
on the road again.
post #14 of 14 Old 04-11-2010, 06:32 PM
hesserdude07
stock YJ rear axle with 4.10s and new brakes. $200 cash. i just did the 8.8 swap. paid 250 for 8.8 and 150 for the MORE swap kit.
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
94" should i Axel swap and Leaf over axel Keiser YJ Wrangler Technical Forum 2 12-20-2008 10:28 PM
axel question turner94yj YJ Wrangler Technical Forum 2 09-24-2008 09:59 PM
noob axel question FranklinTJ TJ Wrangler Technical Forum 3 09-17-2008 03:53 PM
Front Axel Seal for Solid axel swap Mighty Thor YJ Wrangler Technical Forum 4 03-04-2007 11:13 AM
Wet Axel Question? General Jackson TJ Wrangler Technical Forum 9 01-23-2006 02:10 PM
