AX5 won't shift into 1,3,5th gears - Page 2 - JeepForum.com
post #16 of 30 Old 11-03-2013, 06:29 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Any updates?
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #17 of 30 Old 11-03-2013, 08:42 PM Thread Starter
bartlett93yj
Ok- so here is the update. I took the back half of the transmission off while still on the jeep (I read a thread on how to do this while installing a locking collar on gear 5). I removed the locking collar that I installed the previous day. I also made sure that the pivot pin was reinstalled that way Mean Max said to. I also made sure that all the shifting rails were lined up and it was in neutral when I put the fork/shift lever housing back in. Next, I put new casket maker on the back half of the case and reinstalled the bolts. I then reinstalled the detent ball (though I think it was fine). New 10w/30 oil installed, transfer case, drive shafts, cross member, ATF fluid, and all connections complete. On to the shifter. I jiggled the shifter while putting downward pressure to get it set, took a pair of needle nose pliers and spun it/locked it (clockwise). It locked in place.
I went for the test drive and everything was great!!! A huge thanks to Mean Max for your help!!! Thank you.
So... what was it that caused it to not shift properly? Not sure but it's fixed. In hind sight, I was thinking that the shifter wasn't set properly in the housing and wasn't allowing it to shift into 1,3,5. However, I don't think this was it as it as the shifter shaft (that you hold on to) was almost touching the climate controls on the dash when it wasn't shifting right. When reinstalled, the shifter post/lever is positioned where it should be in the cab.
Was it the collar? I don't think so. It doesn't appear that anything was running into it and I couldn't visibly see anything running into it. (5th gear collar for sale!)
Was it that ball bearing/spring? I don't think so- I think I had that in right.
I am leaning toward the shifting rails that might have been in a wrong position as the culprit. Though I have nothing to back this up as I have never done any work on a transmission before and I have no previous experience with them. Is it even possible that the shifting rails would cause this?
Again, a super huge thanks to Mean Max. Though I'm not sure what fixed it, it's fixed and shifts great! I going to bundle up the kids cause we are taking the jeep to school tomorrow!
luke
bartlett93yj is offline
post #18 of 30 Old 11-03-2013, 08:55 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
YAAAAYYYY!!!
Glad you got it fixed!
Right from the first conversation we had, I knew you'd get it handled right away!
Congratulations!
Max
Mean Max is offline
post #19 of 30 Old 11-12-2013, 10:29 PM
j33per
Hmmmm, awkward - I'm actually running into the same problem. I recently had the AX5 tranny out on my 95 YJ during my body-off rebuild and I split the case to install new gaskets (it was leaking like a sieve). Being the genius that I am, I have the trans in and body on and NOW realize it won't go into 1, 3, or 5th gear
My question is: Is there any way to tell if I have the pivot pin in correctly by looking top down without removing the back of the trans?
Thanks so much for your help - this forum is a life saver!
j33per is offline
post #20 of 30 Old 11-13-2013, 05:03 PM
Mark05059
I believe you can remove the 4 bolts at the top for the shift housing and check it that way?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #21 of 30 Old 11-13-2013, 07:54 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Nope, you have to pull the transfer case.
Max
Mean Max is offline
post #22 of 30 Old 11-14-2013, 01:40 PM
j33per
Well, I'm hoping to dig into it tonight. I'll keep you posted!
j33per is offline
post #23 of 30 Old 11-16-2013, 11:02 AM
j33per
OK. So I've figured out my problem, and I'm hoping I can save someone else a headache.
Before I pulled the transfer case I thought I would remove the top shift cover and check the shift arm pivot pin. I was able to run through all the gears!
It turns out I had the top shift cover on backwards!! (How I did that, I have no idea!)
As you can see from the photo, the hole for the shift lever is not centered. Notice that the longer case "lines" go towards the front of the trans.
I reassembled and it works great.
**** Hoping my mistakes make your life easier ****
j33per is offline
post #24 of 30 Old 11-16-2013, 03:14 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
For the AX-5.
Opposite for the AX-15.
Max
Mean Max is offline
post #25 of 30 Old 11-16-2013, 03:20 PM
j33per
Thanks for clarifying, Max!
j33per is offline
post #26 of 30 Old 07-21-2017, 11:30 PM
scottlthomson
Could this be true on an nv3550? I put a used nv3550 in my jeep, on the bench it shifted in all gears installed just 1 3 5 worked? Could I have installed the shift cover backwards?
scottlthomson is offline
post #27 of 30 Old 07-22-2017, 08:39 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Being your first post, I was going to say welcome to the forum. But it looks like you've been a member for four years.
I don't know much about TJ's or NV3550, but do you still have the boot off? The shifter could be hitting either the tub or the boot.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #28 of 30 Old 07-22-2017, 09:58 AM
project_mercy
From what I can tell by looking at the shifter tower gaskets, there is a difference in which direction it gets bolted in and it looks like someone could transpose it pretty easily. I have no idea if that would deter shifting or not, but I imagine it doesn't help.
I echo Mr. B when I say you're better off asking in the TJ forum.
With your help I will resist the urge to buy a chrome grill guard for yet another day.
project_mercy is offline
post #29 of 30 Old 07-22-2017, 02:30 PM
scottlthomson
Originally Posted by Mr.B
Being your first post, I was going to say welcome to the forum. But it looks like you've been a member for four years. I don't know much about TJ's or NV3550, but do you still have the boot off? The shifter could be hitting either the tub or the boot.
Not hitting anywhere I have the tub covers off..
post #30 of 30 Old 07-22-2017, 04:09 PM
Mr.B
Mr.B's Avatar
Well then as suggested, you probably ask in the TJ forum.
Ham license:
Everyone is Welcome
Mr.B is offline
shifting problem
